11-07-2024
19:40
07:07
FatimaFitbit
11-07-2024
19:40
07:07
FatimaFitbit
The screen is not working What is the solution please? The screen is fixed. I cannot move up or down. I only see the main interface.
11-08-2024 07:11
11-08-2024 07:11
Hi there @Rodwan! Welcome to the Fitbit Community! It's great to see you here!
Thank you so much for informing us about this situation.
I suggest you try to follow these steps:
1. Sync your Luxe with the Fitbit app
2. Restart your device:
3. Change the clock face.
4. Sync your Luxe with the Fitbit app again.
Best Answer11-14-2024 18:38
11-14-2024 18:38
Same here. I have had my Fit-bit Luxe for almost a year now and the screen is not completely responding to my touch. I can't swipe up or down very easily making it very difficult to see exercise statistics as well as other crucial functions. To put it into context it acts as if I'm using it underwater or in the shower
Best Answer11-16-2024 05:23
11-16-2024 05:23
Hi there @The-Ok-Duck! A warm welcome to the Fitbit Community!
Thank you for letting us know that you're having the same situation.
In this case, please contact support if you haven't already.
Fill out the form. You will then be recommended some help articles. After that, you will be able to choose how to contact support.
