08-02-2021
03:15
04:58
08-02-2021
03:15
04:58
Hi I bought a Luxe a couple of weeks ago and having the common sync issues, it will only sync and update when the watch is attached to it's charger.
I have until 27 August to return it to Amazon so wonder if there is likely to be a fix for it by then as I don't want to risk losing my money back on a product that isn't performing as it should.
Is there an actual date that Fitbit expect it to be sorted by please - i love the watch but don't like the bluetooth sync issues?
08-02-2021 05:01 - edited 08-02-2021 05:01
Hi there, @jodiplaros. Welcome to the Community Forums. Thanks for the details provided in your post. I understand where your concern is coming from. We‘re taking into consideration your comments and sentiments in regards to our products.
If you haven't done so yet, please follow the steps below:
If the above doesn't work, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected.
Hope that helps.
08-03-2021 08:46
08-03-2021 08:46
Same issues. So frustrating:((
Best Answer08-03-2021 08:46
08-03-2021 08:46
Does NOT work.
Best Answer08-03-2021 11:16
08-03-2021 11:16
Don’t wait you need to send back and get a new one. I have had three now! The first screen went faulty, the second was so poorly put together the edges of the outer case were like razor blades so on to my third. I think FB have a problem with their manufacturing as the quality has gone right down. Shame really.
Best Answer08-03-2021 12:30
08-03-2021 12:30
no it doesnt work for me either! 🙁
Best Answer08-03-2021 12:32
08-03-2021 12:32
Hi nicky
is yours syncing ok with your phone now?
i tried all the steps the moderator said plus what they said to do on the online chat and will not work. Only way of viewing your steps etc in the app is to take the watch off and connect it to the charger
very disappointed
Best Answer08-03-2021 12:39
08-03-2021 12:39
Hi none of the above worked unfortunately
tried the online chat and did what they suggested and still does exactly the same
do you know when the firmware fix for the sync issue will be released please????
Best Answer08-03-2021 23:38
08-03-2021 23:38
Send it back to Amazon. Don’t put up with a shoddy product. I am now using my 3rd luxe so fingers crossed this will work properly. Good luck!
