12-27-2021
12:56
17:06
12-27-2021
12:56
17:06
I had this for Christmas, it worked fine then this morning it wouldn't turn on when I double tapped it, had to reset it twice before it worked again, it hasn't synced to my phone at all even after I have done all the troubleshooting tips etc, nothing at all, can't get it to sync, even tried it manually and still nothing. What do I do? Is it broken or is this a problem on the fitbit app side?
Best Answer12-28-2021 17:09 - edited 11-20-2023 03:50
Hi there, @Louapple @SunsetRunner. Thanks for stopping by in the Community Forums and trying to troubleshoot the issue with your Luxe devices. I understand where your concern is coming from.
in addition to the steps you've done so far, please try removing the Bluetooth connection between your phone and your Fitbit device:
*On your phone, tap Settings > Bluetooth > the information icon next to the name of your Fitbit device > Forget This Device.
*Open the Fitbit app and set up the connection again. You should receive a message asking you to allow your Fitbit device to pair with your phone. Tap Pair to approve the request.
Sync your Luxe automatically when you open the Fitbit app or manually by tapping your profile picture > your device tile > Sync Now.
If the issue persists, see Why won't my Fitbit device sync?
Hope that helps.
12-28-2021 04:54
12-28-2021 04:54
Hi there
Mine occasionally won’t sync and the only thing I’ve found that works is to charge it and press the little button on the black part of the charger 3 times.
I saw it in a YouTube video.
“From:-
WorldofTech
Fitbit Luxe: How to Sync,
Pair, Unpair, Repair (Can't S..”
He goes through a lot of ways to troubleshoot and sync it.
Hope that helps!
Hope that helps.
11-10-2022 18:52
11-10-2022 18:52
Hello,
Doing the steps you mention, will any data that has not been synced be deleted?
Thanks
Gail
Best Answer11-11-2022 09:50 - edited 06-01-2023 14:43
Hi there, @Socksnsocks. Thanks for stopping by in the Community Forums.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
