02-24-2025
00:14
07:23
02-24-2025
00:14
07:23
So yesterday morning I got up and my Luxe would not sync at all. I spent the ENTIRE afternoon following the steps recommended uninstalled the app reset blue tooth etc etc etc - Searched the topics for an answer and found zero assistance but plenty of apologies. In the end I removed the device from the app and added it back - BINGO! it worked. NOWHERE in the suggested fixes does it say to do this , Nowhere! I think its time to change to Garmin or Apple , since the Google takeover its nothing like as good as it used to be.
02-24-2025 14:58
02-24-2025 14:58
Toni1964, I have the same problem. Would you mind posting details of how you removed the device from the app and added it back? Thanks!
03-09-2025 14:00
03-09-2025 14:00
Hi, I had the same issue this week, tried all steps, none worked. Then I saw this post and it worked by removing the device from the app. You have to go to the app on your phone, click on the Fitbit device symbol, click on Luxe (screen where you have the notifications and other settings options) and select the delete sign on the top right. Follow the instructions to add the device again
03-11-2025 18:04
03-11-2025 18:04
H @Toni1964 @KathyOsh @Barbara2025. Welcome to the community forums.
Thank you for providing the details regarding the difficulty that you are experiencing with Luxe.
Please make sure that you are using the latest version of the Fitbit app.
In addition, take a look at the points listed in this help article: How do Fitbit devices sync their data?
03-16-2025 05:55
03-16-2025 05:55
Thank you!
Best Answer03-24-2025 19:45
03-24-2025 19:45
I am having same problem and same thoughts about whether I continue with Fitbit and Google. Also have Pixel phone and not happy. Software upgrades move everything. Thanks for your help.
03-25-2025
01:02
11:09
FatimaFitbit
03-25-2025
01:02
11:09
FatimaFitbit
Hiya, I uninstalled the app, restarted my fit bit it was a right pain. I
am going to see out my premium subscription!
Moderator Edit: Word choice.
10:08
10:31
FatimaFitbit
03-29-2025
10:08
10:31
FatimaFitbit
I would like to know why my Fitbit Luxe is always disconnecting? I have to go through hoops everyday, including removing the device, uninstalling reinstalling and then adding the device. This can sometimes require 4 or 5 goes at it before that magic number appears on the Fitbitthe app, to get it to talk to the app etc. Is it more than coincidental that the Luxe doesn’t appear in the Fitbit shop?
Moderator Edit: Formatting
Best Answer04-11-2025 16:55
04-11-2025 16:55
Hi @Izzywizz57 @Shazeemie. Good to see you for the first time in the community.
Thank you @Izzywizz57 for the information that you share with us regarding your Luxe.
I'm not sure if you are still experiencing this situation with your Luxe. If so, please make sure to follow the steps listed below:
With the steps above, what I want you to do is to pair your Luxe first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Best Answer04-12-2025 01:26
04-12-2025 01:26
