03-05-2024 03:48
03-05-2024 03:48
How to I navigate away from the exercise mode on my Fitbit Luxe when I have finished my exercise. if I touch the screen at all it starts the exercise again. I have read you double tap firmly but on the first tap the exercise starts. I have found one spot at the top of the screen that if you hit just the right spot about every 10th attempt it will return to the time screen. Meanwhile I have to delete each one of the 10 started workouts on my phone Not got the hang of this at all.
03-05-2024 12:25
03-05-2024 12:25
@Octavia13 I find that two quick taps in the upper left hand corner of the screen is all it takes to exit the workout app.
Best Answer03-05-2024 12:45
03-05-2024 12:45
03-05-2024 13:52
03-05-2024 13:52
@Octavia13 Hmm. Have you tried restarting the device? If a restart doesn't work, then I'd assume it's a hardware malfunction and you should definitely try to get a replacement.
03-05-2024 14:21
03-05-2024 14:21
