12-19-2013 12:55
12-19-2013 12:55
Hey Guys. I am in Austin, Texas.
I just started a comprehensive medical supervised Fat Loss program that focuses on fine tuning your metabolism to burn fat using nutrition, hormones, exercise, lifestyle changes, and cleansing. Part of the program is using the fitbit. The program is 90 days. My goal is to lose 50 lbs. in 90 days.
The first 40 days are done with a hormone called hCG. You have to eat like a PIG for two days at buffets, but you have no appetite after the first and have to force yourself to eat on the second. You get a pedometer that counts ONLY your steps, unlike the fitbit that counts your arm swings.
You have to go to a High Intensity Training center where elite trainers do a Body Fat composition test using a BodPod that is highly accurate. They check to see your Fat Loss to Muscle loss ratio and give you your personal calorie requirements for your body.
You have to eat a very specific diet that causes the hCG to make your body eat your own fat at 1/2 - 1.5 lbs. a day, depending on how much fat you have, your gender and your current health. It has meats, veggies and fruits. You also have to drink tea to help get the fat out of your body. Here is something I did not know, if your poop floats, then you are excreting fat in your poop.
You are supposed to walk 3K - 5K ACTUAL steps each day, but NO aerobics or weights yet. You can do Yoga and stretching too if you want, but nothing that makes you go aerobic for long periods. Increased heart rates are good, but they say that during hCG hormones if you do high intensity then you will burn your muscle off, which is not what you want if you want a good metabolism.
They look at your fitbit logs and see what you are doing. Every day you get a new Metabolic Lesson to learn and answer questions on. You get lessons on nutrition, hydration, infections, yeasts, alkalinity, hormones, habits, and even on how things are marketed to make you buy them and consume too much.
After the first 40 days, then you switch over to a healthy diet with good food to change your life style habits to keep you losing fat and start building a little muscle, but really getting your metabolism going.
Turns out that after 30 or so, your hGH (Human Growth Hormone) starts dropping and your metabolism slows because your sex hormones also drop. The hGH is the master control hormone that regulates almost all other hormones. As you age the hGH drops and all your other hormones drop too and you get fat. So even if you lose weight on a diet, you will get it all back if your hormones are not balanced properly. Like insulin (makes your body store fat), Leptin (makes your body feel full and burn fat, Thyroid hormones - triiodothyronine (T3) and thyroxine (T4), responsible for regulation of metabolism. Serotonin (helps you sleep and recover), Cortisol ( breaks down muscles and slows your metabolism), Testosterone (male sex hormone that makes you burn fat and gain muscle and have a good sex drive), well, anyway there are a lot of hormones that are controlled by hGH.
My hormone tests showed lower hGH and Testosterone and that will make me gain the weight back if I dont get those back up. I have to take injections that will activate my adrenal glands to make hGH and also have Testosterone injections after the hCG hormone phase.
The elite trainers will put me on a special TIMED eating schedule to make me burn even more fat and increase my hGH where I only eat for a specific 8 hour period and have nothing for 16 hours. It is the same TIMED program Hugh Jackman was on to lean out for his Wolverine movie.
The exercises move into short burst 5 - 10 minute intensity to stimulate the metabolism even more with some small muscle gains.
Hormone levels are checked, body composition is checked, nutrition is checked and education level is checked. So over 90 days, I am shooting for a realistic (I'm told) 50lbs of Fat loss and 10 lbs of muscle gain.
My starting stats are
244 lbs. 6'1"
153.7 lbs. of muscle
71 lbs. of Fat
Testosterone levels at 425 (range 0 - 1000+)
hGH level at 5 (0 - 12)
If anyone wants to know more, I will be glad to answer your questions.
02-01-2020
04:05
06:36
AlvaroFitbit
02-01-2020
04:05
06:36
AlvaroFitbit
I wonder if HGH is safer than HCG. I heard that HGH works well for weight loss. However, getting one can be a little difficult unless you are actually growth deficient.
Moderator edit: removed advertising link
