@caribbeandream - calories to eat default to the sedentary setting. This means at any point in the day it assumes that you're not going to move after that point. This can give you extremely low calories earlier in the day. I'd suggest that you eat your 1200 and see where you end up at the end of the day. Depending on your activity level even the 1200 a day might be too low. I like this site:
http://www.fat2fittools.com/tools/bmr/
Assuming that you're mid-20s and female, your BMR comes out to 1334. This is usually the number they suggest you don't eat below.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
Best AnswerThere are no good or bad foods, though when desired aim to get 90% of the calories to come from natural foods as dear @marfar suggested (10% for treats and prevent binge eating).
Natural foods leaving satisfied for longer on lower calories overall, these also contain essential nutritients for the body to use (for repairing muscles, growing your hair, nails, regenerating skin, quicker healing when injured, being less sick as aiding the immune system to recover faster)..
Calories matter, food quality does to. The foods with labels are faster to log (since having a label), though natural foods (without labels) are the best for the body.
The body should crave when hungry for natural foods as nature intended us to have, though if a non natural food craving appears and doesn't go away, possible to have with care, enjoy the taste, prevent binge eating and beats the craving.
When eating natural foods mostly, the body gradually desires to have those foods instead over time, not wanting 'junk foods' anymore..
Junk foods = preprocessed foods, mostly with added sugars to want even more from even if not hungry anymore, just for the taste, higher in calories, not leaving as satisfied as natural foods do. As the body desires to want more foods to get all the nutritients it needs..
Well, you have to pick a point to start. With the extra details, you see:
Custom BMR Calculation
Entered information: 41 year old female, 60 inches tall, weighing 118 pounds.
From the information that you entered, you'd like to weigh 110 lbs.
Harris-Benedict Formula
There are a few different methods to calculating yourbasal metabolic rate (BMR). One of the most popular, developed in the early 1900's is called the Harris-Benedict formula. Based on this formula, your current BMR is 1259 calories.
So if you do nothing all day your body will burn 1259 calories, That's the lowest that you should probably eat. The site gave the following for weight loss:
Activity Level Daily Calories
| Sedentary (little or no exercise, desk job) | 1469 |
| Lightly Active (light exercise/sports 1-3 days/wk) | 1683 |
| Moderately Active (moderate exercise/sports 3-5 days/wk) | 1897 |
| Very Active (hard exercise/sports 6-7 days/wk) | 2111 |
| Extremely Active (hard daily exercise/sports & physical job or 2X day training, i.e marathon, contest etc.) | 2326 |
NOTE: Please remember that this calculation is just a guideline. Your metabolism may be higher or lower based on the amount of lean muscle you have. Use these numbers a a starting point and tweak them up or down based on your weight loss or gain. It may take a couple weeks to get your exact calorie level.
No problems. I find it relatively close for myself. I eat to what it tells me I need to eat for lightly active, however, I've got a lot of weight still to lose. From my Charge 2 I figure I'm closer to the mid-point, but at the moment I'm more interested in a slightly faster loss. Good luck. ![]()
Thank you for the link, very helpful!
880 kcl bad very bad idea for you.
more problems than benefits, not worth it.
@marfar wrote:
I do not know how my advice is worth. It is the advice of a friend. Feeding cells is the key to health, not calories!
We have fifty trillion cells (Bruce Lipton - Biology of faith)! Nourishes blood, lymph cleanse! The engine of blood is the heart, lymph engine is brisk walking! Alkaline food, brisk walking, forgiveness, prayer, meditation are simphony of nutrition!
The theory about calories burned is outdated! Alkalizing the body is healthy!
I started to understand watching the documentary ,,Forks over Knives" . And serious study of naturopath! Hiromi Shinya, Candace Pert, Mikhail Tombak, Bruce Lipton and others, are required reading! Otherwise, count goofy how many calories entered and left the body! Fat covering garbage from cells because we do not move lymph!
But we do not understand why we are tired! And why we gain weight!
Although burn calories !!! Many !!!
I do not advise that keep so! It is the advice of a friend who has results! The body responds when it is fed healthy and clean lymph! Experienced made!
I would be happy when YOU will be healthy!
I repeat: it is disinterested advice of a friend!
@marfar - reading your posts is like reading the Dr. Bronner's soap label sometimes...
If not now, when? If not you, who? All One! All One!
Best AnswerNo, not irony... I just think your distinctive style sounds a lot like the Dr. Bronner's label. It's All Good. 😃
@marfar wrote:
what govern us, are hormones (insulin), not calories! The calories are not equal! A calorie is not just a calorie !!!
See my long response to your other post: a calorie is a unit of energy, and as such a calorie is a calorie. Now, not all foods have the same nutritional value for the same amount of calories, but that’s another matter.
Dominique | Finland
