04-30-2015 00:46
04-30-2015 00:46
Best Answer05-01-2015 03:06
05-01-2015 03:06
Yep, I frequently have to go for a run to earn some calories for my tea.
05-01-2015 03:28
05-01-2015 03:28
it will raise your metabolism is you exercise but you will do better if you just bank those extra calories.
04-30-2015 00:49
04-30-2015 00:49
Best Answer04-30-2015 00:51
04-30-2015 00:51
Best Answer04-30-2015 04:26
04-30-2015 04:26
yes calories in versus calories out. But you have to measure how much you should be eating to maintain or lose. 3,500 is one pound. I look at extra earned calories or lost weight as in the bank and I want to build that up. Hope that helps.
Eileen
Best Answer04-30-2015 04:44
04-30-2015 04:44
Best Answer04-30-2015 04:48
04-30-2015 04:48
Best Answer04-30-2015 04:55
04-30-2015 04:55
It list the number of calories you should have each day if you put the information in on how much you want to loose. If you go over one day just get back on track the next day.
04-30-2015 05:04
04-30-2015 05:04
Best Answer04-30-2015 05:54
04-30-2015 05:54
Probably not, the chacne of yo-yoing is extreme, your over indulge, then you'll try and starve yourself, then you'll crack and eat a block of cheese, and then you'll be worse off.
04-30-2015 05:55
04-30-2015 05:55
Your body resets so just go as you should and try to avoid the slip ups. Everyone had slip ups so don't worry that was yesterday and today is a new day 🙂
04-30-2015 08:05
04-30-2015 08:05
It is automatically added into your allotted calories. If you eat those calories plus what is says, you are over eating.
You can see that on the days you get more steps and etc that your allotted calories go up.
Best Answer04-30-2015 14:38
04-30-2015 14:38
05-01-2015 03:06
05-01-2015 03:28
05-01-2015 03:28
05-01-2015 03:47
05-01-2015 03:47
Best Answer05-01-2015 04:11
05-01-2015 04:11
I have the flex not charge - hope someone can answer that who has the charge otherwise under help forums you can pick the charge and can find lots of question/answer about it.
01-25-2018 12:02
01-25-2018 12:02
I found this to offer: For each 3500 cal you eat in excess of expenditure you store approximately 1 pound of body fat. Pure fat is worth 9 cal per gram ( a pound of it 450 grams), then would store 4150 cal. A pound of body fat is not pure fat though it contains water protein and other materials ( hense the lower calorie value,)
