10-04-2018 04:29
10-04-2018 04:29
Best Answer10-04-2018 07:23
10-04-2018 07:23
Go to the website dashboard then click Food Tile -> "see more" -> which will take you to the food log page, go to the "food plan" (second box down) and click the arrows until your "desired weight/calorie target" slide shows, click "edit plan" the click "edit" at the end of the sentence that starts "Your staring weight was ..." Once you get to that screen you can change the start date and weight.
Hope that helps.
Scott | Baltimore MD
10-04-2018 07:23
10-04-2018 07:23
Hope that helps.
10-04-2018 17:50
10-04-2018 17:50
Hi Baltoscott,
Your explanation of what I needed to do was perfect.
Thank you,
Whoberley
Best Answer10-07-2018 05:15
10-07-2018 05:15
