05-02-2014 12:56
05-02-2014 12:56
Is there a way to add a component to the dashboard that I can input body measurements for further tracking. I would rather have all that information in one place instead of keeping a notebook for measurements....
If not, I think that would be an ideal feature to add.
05-02-2014 15:28
05-02-2014 15:28
You can log measurements. Click on Log, select Weight and page down. Towards the bottom of the page you'll see a link to click on for adding measurements.
Best Answer05-02-2014 13:50
05-02-2014 13:50
I know that myfittnesspal and Fitbit work together and you can do measurements on that site.
05-02-2014 15:28
05-02-2014 15:28
Best Answer05-02-2014 15:39
05-02-2014 15:39
Ahh! Thanks! I missed that.
Know of any plans to add that to the app?
Best Answer05-02-2014 23:18
05-02-2014 23:18
I'm afraid not, but you could write to them and suggest it. The tape measure never lies, it would be a good thing to add to the app - or at least a note/journal section.
Best Answer08-19-2015 04:29
08-19-2015 04:29
I don't see a way to export measurement data from myfitnesspal although it is good that one can post their measurements there.
Best Answer02-19-2016 08:42
02-19-2016 08:42
These were removed! Why were they removed? Isn't this what fitbit is supposed to be all about?
02-20-2016 00:41
02-20-2016 00:41
bhahaha! No, fitbit isn't about overall fitness; it is just about expensive wrist-bands that tell you how many steps you've taken in a day.
Best Answer02-20-2016 03:36
02-20-2016 03:36
@Page75 wrote:These were removed! Why were they removed? Isn't this what fitbit is supposed to be all about?
I personally agree it’s a pity they were removed, but it’s not the end of the world either. Since you must manually write them down anyway and you are typically not doing it every day, you can just as well enter them in your own Google Sheet or equivalent. And you can then draw fancier graphs than was possible in Fitbit.
Dominique | Finland
Best Answer02-20-2016 14:40
02-20-2016 14:40
I'm actually most bummed because I wanted to recall the measurements I made 2 years ago when I bought my fitbit 😞
Best Answer02-20-2016 15:04
02-20-2016 15:04
@Page75 wrote:I'm actually most bummed because I wanted to recall the measurements I made 2 years ago when I bought my fitbit 😞
When Fitbit decided to retire that feature, they sent you an e-mail on Aug-14, 2015 ("Important Notice: We're retiring a few logging features") that pointed to this post.
Dominique | Finland
