08-31-2017 11:27
08-31-2017 11:27
Hi Everyone,
What's the website that shows you the amount of calories you can eat (for the rest of your life) and lose weight but them eventually maintain on those calories?
08-31-2017 13:56
08-31-2017 13:56
Do you mean this one? It’s not exactly "for the rest of your life", since the equation it uses (Mifflin St Jeor) relies on age as one of the factors affecting BMR and TDEE: as you get older, you expend less energy (all things being equal), so you will need to eat less in order to maintain the same weight.
There’s another equation – Katch McArdle – that doesn’t involve age, nor gender: it’s based on body fat and weight. It’s less commonly used, though.
Dominique | Finland
Best Answer09-05-2017 07:52
09-05-2017 07:52
Thanks! I don't think that's it. That one is helpful though. Thanks!
