Hey!
For the last couple months on average a day I will eat 1100/1200* calories as I didn’t have knowledge on the ‘right’ way to diet, I think that deficit was too large so I have upped my calories to around 1300/1400 a day, with exercise on average I burn 2000/2100 calories, if I just jump up my calories by 300 will my body adjust or will my body freak out at the new intake and store them as fat?
Female
20 years old
5ft 2
112 lbs
How much did you lose during the two months you ate 1100/1200? Asking in order to determine whether the deficit was "too large", as you’re thinking. Because you are petite and thin (BMI: 20.5), it makes the case for not doing anything crazy one way or another (when cutting calories or increasing them). If you want to play it safe, go for half the amount you had in mind (+150 instead of +300), see what happens and adjust accordingly.
Dominique | Finland
Even at your "heaviest", you were still BMI 23.4, i.e. well within the normal weight range. From your current weight of 51 kg or so, you can well afford to gain a couple more kilos, even if that comes with a little bit of fat.
Dieting for 8 months straight is quite long and taxing, even when losing at a very reasonable pace (0.25 kg per week). And 8 kg when you’re 58 is 14% of your starting weight, which is a lot. I did something similar in 2017, going from 68 to 60 kg in 10 months (i.e. very slowly):
I retrospectively think it was too long and I have since kept cutting phases to 3-4 months max. This is what the past couple of years look like:
I find it psychologically easier to diet more aggressively for shorter periods of time.
Dominique | Finland
