07-18-2018 11:16
07-18-2018 11:16
Just wondering on the accuracy of Calories Burned on my fit bit blaze. I pull a press handle majority of the day, I average between 2500-4000 “calories burned” a day
not sure that’s entirely accurate which makes it a little difficult to know how much I should/could ACTUALLY eat
I am on a 2000 calorie intake a day schedule at the moment
my heart rate stays in fat burn mode all day with a few hours a day getting into cardio
i also work out after work at home, but those calories burned aren’t included in the previous ones I mentioned
Im not gaining weight, I am losing it, it’s more of a desire to know how “off” my readings could be
Thanks
Best Answer07-18-2018 13:12
07-18-2018 13:12
You probably have had your Blaze for some time (given it’s no longer a current model). This means you should have enough historical data (in terms of calories burned). If you’ve also been logging your intake and weighing yourself for some time, you can then compare predicted weight changes to actual weight changes. This in turn should tell you by how much your Blaze over- or underestimates your energy expenditure (assuming you’re 100% accurate in loging your intake).
You can also double-check your numbers by using an online calculator such as this one. You can use your average step count as a proxy for determining which of the five standard activity levels applies to you.
Dominique | Finland
Best Answer07-18-2018 14:15
07-18-2018 14:15
