03-15-2015 14:08
03-15-2015 14:08
Best Answer03-15-2015 16:52
03-15-2015 16:52
Following, I would like to know too.
Best Answer03-15-2015 22:54
03-15-2015 22:54
Never seen it.
But then again, even though weight comes down and you burn less moving that mass around, as you've gotten more fit with exercise, shouldn't you also be moving with more intensity burning more, and easier to walk daily so you do more of it?
I'm guessing they figure it should be a wash.
If you still want to eat 2000 calories daily because you know you'll sustain and adhere to that level, and you want to lose 1 lb weekly, then your daily burn goal remains at 2500 even though you weigh less.
Best Answer03-16-2015 00:20
03-16-2015 00:20
Best Answer03-17-2015 21:28
03-17-2015 21:28
@ThePreacher wrote:
I did some more digging and it looks like those with a premium account it auto adjusts because of the trainer feature.
Now my question is how do the rest of us manually readjust it?
Through the web account anyway, on Dashboard click on that tile, click the settings icon, change the number - Done.
