I find the calories left / burned display a bit annoying. When you look at it on the dashboard or on my versa lite, it might say you have 2000 calories left to consume, but when you open the feature on dashboard you find that you are over your food budget compared to calories burned. When you are striving for weight loss you want to make sure you burn more than you consume. Also i can't see where you can adjust what your total calorie intake should be for the day.
Hi @CynnyK , nice to see you around. Thanks for your feedback and your inquiry regarding the adjustment of the calories intake.
You can change the total calorie intake for the day, depending on your goal (lose or gain weight) .
In order to adjust it, you 'll have to create a food plan in the Fitbit app.
Instructions and tips can be found here:
How do I track my food with the Fitbit app?
Please keep posting
