โ04-06-2020 18:47
โ04-06-2020 18:47
Can i Lose 10kg doing this everyday with a relatively good diet
What are you're suggestions to improve this???
๐๐๐ง๐๐๐ค
2 ๐ข๐๐ฃ๐ช๐ฉ๐ ๐๐๐๐ ๐ ๐ฃ๐๐๐จ
50 ๐๐ช๐ข๐ฅ๐๐ฃ๐ ๐๐๐๐ ๐จ
2 ๐ข๐๐ฃ๐ช๐ฉ๐ ๐๐๐จ๐ฉ ๐๐๐๐ฉ
50 ๐ฃ๐ค ๐ง๐ค๐ฅ๐ ๐๐ช๐ข๐ฅ๐จ
๐๐๐จ
20 ๐๐ง๐ช๐ฃ๐๐๐๐จ
20 ๐จ๐๐๐ ๐ฉ๐ค ๐จ๐๐๐ ๐๐ง๐ช๐ฃ๐๐๐๐จ
20 ๐ก๐๐ ๐ก๐๐๐ฉ๐จ ๐ค๐ฃ ๐๐๐๐
20 ๐ก๐๐ ๐ก๐๐๐ฉ๐จ ๐ก๐๐๐ฉ
20 ๐ก๐๐ ๐ก๐๐๐ฉ๐จ ๐ง๐๐๐๐ฉ
20 ๐๐ช๐จ๐จ๐๐๐ฃ ๐ฉ๐ฌ๐๐จ๐ฉ๐จ
20 ๐ ๐ฃ๐๐ ๐๐ง๐๐ซ๐๐ง๐จ
20 ๐๐ง๐ค๐จ๐จ ๐ข๐ค๐ช๐ฃ๐ฉ๐๐๐ฃ ๐๐ก๐๐ข๐๐๐ง๐จ
2 ๐ข๐๐ฃ ๐ฅ๐ก๐๐ฃ๐
๐๐ค๐ค๐ฉ๐ฎ / ๐ก๐๐๐จ
20 ๐๐ฃ๐ ๐ก๐ ๐๐ช๐ข๐ฅ๐๐ฃ๐ ๐๐๐๐
20 ๐จ๐ฉ๐๐ฃ๐๐๐ฃ๐ ๐๐ก๐ช๐ฉ๐ ๐ ๐๐๐ ๐๐๐๐
20 ๐จ๐ฆ๐ช๐๐ฉ ๐ฉ๐ค ๐ก๐๐ฉ๐๐ง๐๐ก ๐ก๐๐ ๐ก๐๐๐ฉ
20 ๐๐๐ง๐ ๐๐ฎ๐๐ง๐๐ฃ๐ฉ๐จ
20 ๐๐ค๐ฃ๐ ๐๐ฎ ๐ ๐๐๐ ๐จ
20 ๐ก๐๐ ๐๐ญ๐ฉ๐๐ฃ๐จ๐๐ค๐ฃ
20 ๐จ๐ฌ๐๐ข๐ข๐๐ง๐จ
20 ๐ฅ๐๐ก๐ ๐จ๐ฆ๐ช๐๐ฉ๐จ
20 ๐ ๐๐ฉ๐ฉ๐ก๐๐๐๐ก๐ก ๐จ๐ฆ๐ช๐๐ฉ ๐ฌ๐๐ฉ๐ ๐ 3-๐จ๐๐๐ค๐ฃ๐ ๐๐ค๐ก๐
2-๐ข๐๐ฃ๐ช๐ฉ๐ ๐ฌ๐๐ก๐ก ๐จ๐๐ฉ
๐๐ง๐ข๐จ
20 ๐ฅ๐ช๐จ๐๐ช๐ฅ๐จ
20 ๐๐ช๐ง๐ก๐จ
20 ๐๐ช๐ข๐๐๐๐ก๐ก ๐ง๐๐๐จ๐๐จ
20 ๐๐๐ฃ๐ฉ ๐ค๐ซ๐๐ง ๐ง๐ค๐ฌ๐จ
20 ๐ค๐ซ๐๐ง๐๐๐๐ ๐ฅ๐ง๐๐จ๐จ
2-๐ข๐๐ฃ๐ช๐ฉ๐ ๐๐ง๐ข ๐๐๐ง๐๐ก๐๐จ
Best Answerโ04-09-2020 15:55
โ04-09-2020 15:55
@jaderho weight loss starts in the kitchen, so instead of focusing solely on what you are doing, I would be curious what "relatively good diet" is defined as. You need to eat within a caloric deficit in order to lose weight. If couple that with activity, it will give you an opportunity to eat a bit more, but if you are targeting weight loss, not overall fitness, you want to check in with good low fat high nutrition food choices.
Elena | Pennsylvania
Best Answerโ04-10-2020 00:04
โ04-10-2020 00:04
Best Answerโ04-14-2020 06:03
โ04-14-2020 06:03
You will certainly gain muscle with that regimen. Were you exercising at all prior to this? What percent of your current weight is 15kg?
As another poster said, weight loss starts with what you're putting on your plate. Do you know your current body fat%? Are you drinking plenty of water?
It is possible to eat too few calories to lose weight. Keep that in mind.
โ04-14-2020 16:51
โ04-14-2020 16:51
im currently 65kg, I'm unsure of my body fat %.
I drink at least 2L a day, and usually eat between 1,100 - 1,700 calories a day
Best Answerโ04-15-2020 06:51 - edited โ04-15-2020 06:51
Another note: you'll want to give your muscles a chance to recover, so you should NOT do all of that every day. You've heard "it's leg day" I'm certain... what that means is focus on upper body/core one day, make the next, cardio focused, then do legs the next day, and cardio the next. Take a day off, if you're very sore. Then repeat the cycle.
This way you're challenging/building muscle, and allowing recovery.
