03-19-2015 00:17
03-19-2015 00:17
Best Answer03-19-2015 08:41
03-19-2015 08:41
The numbers increase due to your differential goal. For example, if your goal gives you a target differential (caloric intake vs burn) of 500, once you burn enough calories to nail that differential target, the amount you can intake increases.
By a 1340 intake goal, I'm guessing your target differential is 750? That means once you burn more than 2,090 calories it will increase your intake allotment. That's so you stay within that 750 differential.
Should you eat more? Probably so. 1,340 is pretty low for caloric intake, and if your body is not used to a higher differential, you'll start feeling tired (that's your "sign" that you're not eating enough). After tiredness, you can get dizzy, forgetful, and so on.
In short, if you're hungry, eat. If you're body gives you the signs, eat. Don't "push" it just to burn more - especially as a nurse.
Weight loss is tied to the differential. So eating more when you burn more shouldn't make a difference. There are days I intake more than 2,200, and I'm still on target.
