Looking at your profile, I would favour consistency over intensity:
Wear your Fitbit everyday (24/7), so that there are no "holes" in your history. Set yourself a step goal that you will reach everyday. There is no point in doing a few HIIT sessions here and there as long as you have a lot of days at 4000 steps, which is rather low activity. If the default 10,000 step goal is unrealistic for you at this stage, set a lower one, and progressively raise it over time.
Weight loss is a long-distance race, not a sprint, so what happens after just one week doesn’t matter much.
On the positive side, you have lost more in one week than me in three months ![]()
Dominique | Finland
I agee its not a race. You lost 3.8# thats great!
Wendy | CA | Moto G6 Android
When you become a true Fitbit addict, you will feel naked when you don’t wear it ![]()
I understand you may not be able to wear it on your wrist at some point because of your job. In such situations, just put it in a pocket (instead of putting it in a drawer or similar): even if your Charge HR will no longer track your HR, it will still track your steps and activity level.
Although pacing around your apartment is better than lying on your couch, the best way to get enough steps is to dedicate a set period of time (say, half an hour) to it and go out for a walk.
Dominique | Finland
Ultimately, there are two things that lead to disappointment.
The title of your post says "First week weigh in eh.." and the first line of your post says "my thirst week".
I am unclear if it's your third week or first week. Either way, you lost just shy of 4 pounds in a week - or in 3 weeks.
If it was the first week, I'd say you did just fine. And, if it was three weeks, you still did okay.
Consider what you've eaten and compare to what you've burned. I did this myself and saw that I lost a couple pounds more than I should have due to either errors in logging(packages not accurately representing the caloric values) , or Fitbit errors in calculating calories burned. Either way, it was a less than 10% margin, so I'm okay with that.
High Intensity is great for fat loss. Better than steady state cardio. But - one beer or two will just negate the effort. Once you figure out the calories you need to eat to maintain your weight and not increase it, then you can add the beers back - but keep in mind, they're empty calories doing nothing for you on a nutritional level. Over time, those beers and calories will give you a beer gut - if you don't burn them off.
@Spineshade wrote:
I need to look more into what I eat.
Definitely so. Keep in mind weight loss is 80% nutrition, 20% exercising. No matter how "insane" Insanity is, it won’t offset a poor diet. Same with any other workouts.
Dominique | Finland
Consistency is the key to achieving great results. Just KISS - keep it simple stupid. You can do it. We are with you.
Welcome, and as others have said, it's not a race. None of us put on the weight quickly so we aren't likely going to lose it the same way. I sometimes think shows like the biggest loser give people unrealistic expectations. I think, with only a few exceptions, none of them were able to keep the weight off. Making manageable changes to food and exercise habits is the way to long term weight loss.
I say that because if you lose weight only cutting out beer then likely you'll gain it back when you go back to having those couple of drinks. If you change your habits so that you can still lose weight having those couple of beers... well, that's the ticket. As others have said, diet is the biggest contributor to weight loss. Good luck!
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
