02-25-2014 07:36
02-25-2014 07:36
Is anyone in here using their fitbit along with acupressure in order to lose weight? If so, I'm curious as to how you are using it.
So far, I'm using the alarms to reminde me to rotate the beads every 2 hours and I'm using the weight and food tracker, but I haven't had much use for the step tracker. Is anyone using the beads and walking/running? If so, how does it affect your weight loss?
Also, if you are tracking your sleep, have you noticed changes in your sleep pattern since starting the acupressure?
Best Answer02-25-2014 11:11
02-25-2014 11:11
I've used Accupuncture but mainly from a stress relief and blood pressure standpoint. Weight loss was secondary aspect. I only did it once a week for a couple of months.
I had zero success in regards to weight loss. I weighed 300lbs when I started, and weighed 300lbs when I stopped. My blood pressure may have been reduced a little, but not much. I was high, 160/90 at the start, and was about 155/85 when I stopped. Stress levels was the only success I may have had with it... just that I didn't feel so rushed/panicked... My sleep improved a little at this time, but only because I didn't wake as much.
When I gave that up, and realized that I needed exercise, and a change in diet, that's when I noticed a big difference. 35 lbs later, my BP is in pre-hyperstensive areas now, and I don't feel anywhere near as stressed. Now I'm really sleeping better.
I really wanted to believe in Accupuncture, but I just can't validate it scientifically. By day, I'm a computer programmer. I am also a Licensed Massage Therapist and had hope that Accupuncture would work. For me, the facts didn't back it up. When I look at the sleep improvement during that time, I still can't prove that Accupuncture was the cause of me sleeping a little better.
Best Answer02-25-2014 13:20 - edited 02-25-2014 13:21
I strongly suspect that if you use accupressure along with your Fitbit to lose weight, it's going to be the walking and food tracking that help you, not any kind of beads. I'm not sure what you mean about not having any use for the step tracker, since that's the main function of the fitbit. *headtilt*
Best Answer02-25-2014 13:34
02-25-2014 13:34
Best Answer02-25-2014 16:32
02-25-2014 16:32
I'm not familiar with the beads you're referring to. I just thought Accupuncture because Accupressure is based on the premise of Accupuncture and it's Meridians and pressure points where the needle (or pressure if referring to Accupressure) is placed.
Best Answer02-25-2014 16:36
02-25-2014 16:36
I read about this, because you had me curious. I would say based on the diet you should definitley talk to your GP first.
02-25-2014 17:03
02-25-2014 17:03
Best Answer02-25-2014 17:05
02-25-2014 17:05
Best Answer02-25-2014 18:26
02-25-2014 18:26
I understand that the Fitbit is a pedometer, but I actually haven't been using it to count steps at all. I have been using it to track my weight, water, food, sleep and as mentioned, I'm using the alarms.
