Using the fitbit app I go to the page and enter my weight ... 12stone 11 lbs.. i save it .. I go back to the nmain screen and what do I see ?? my weight is sudenly now 12st 10.9 lbs .. and it doesn't matter what figure i enter .. the lbs figure is always reduced by 0.1 between the weight page and the home page.
May I suggest your programmers find and fix the coding error that can't transfer a simple figure from one page to another without changing it ?
Lets stop adding unwanted rubbish to the app , and make the basics work first ??
Best AnswerFYI - like many apps (though some may not exhibit the error) - they translate all weights to metric for use in many formula's that are used with your info that always use metric figures.
Then a setting says what to translate the metric figures back in to for display to the pesky humans with their different measurement systems.
Your current weight is hitting a rounding error.
How long you plan on being that weight?
I mean, in the scheme of things.
12 st = 76.20352 kg
11 lb = 4.989516 kg
kg added = 81.193036 = 12.78569 stone = 12 st and 0.78569 x 14 = 10.99966 lbs
Or in this case non-rounding error.
I wonder if they are storing that many significant digits after conversion, so:
76.2 + 4.99 = 81.2 kg = 12.8 stone = 12 st and 0.8 x 14 = 11.2 lbs
Wow, they must be storing most those digits for accuracy, but truncating on display instead of rounding.
I'll bet a water fluctuation over the stress of it increases your weight and the error will go away!
@Entwood that actually does happen. It happens between the fitbit scale and what shows up on the dash. It is always 0.1 less on the app. Honestly, I would be more upset if it rounded up and does 0.1 really matter? I understand that it should be accurate, but if you get on the scale, get off and get back on in a minute or so, your weight will be different by that amount or slightly more in either direction as well.
Elena | Pennsylvania
Best AnswerThat's a good point too.
My scale in the specs says accurate to 0.5 lbs.
But readings are given in 0.2 lb increments.
