03-13-2017 07:40
03-13-2017 07:40
Best Answer03-13-2017 22:55
03-13-2017 22:55
@pinkphant: how tall are you? Asking because it’s hard for me to imagine how someone 82.8 lb (37.5 kg) would need to lose weight.
Dominique | Finland
Best Answer03-21-2017 10:21
03-21-2017 10:21
Hi Dominique,
I am 5'4".
Best Answer03-21-2017 10:26
03-21-2017 10:26
Upps! not 82.3 lbs, rather 182.3 lbs which is around 80kg. And I am 5'4" or around 163 cm.
Best Answer09-08-2020 07:03 - edited 09-10-2020 10:00
I think you must discuss this with your doctor. The inability to lose weight is a common concern for people with hypothyroidism. Even when on treatment, there is usually only a modest loss in weight. The weigh lose depend on your metabolism, not only on how mach calories are you eating or how much are you exercicing. Most people with hypothyroidism are treated with thyroid hormone replacement medication, are you shure that it is optimal for you? Check https://www.srsmiami.com/best-sarms-source/ there is a product used by profesional spormens.
