12-20-2017 07:07
12-20-2017 07:07
I was wondering how Fitbit calculates the calorie burn goal. Mine has been the same since I have had it. Lately I have been working out more which has caused my heart rate to lower overall. Now I never hit my calorie burn goal. I can change it but I want it to be accurate so if anyone could tell me how to calculate it myself I could do that and see if it matches. Thanks!
12-20-2017 07:11
12-20-2017 07:11
@David_P have you setup a weight loss plan, and log food? As you log food it will affect the calorie goal.
12-20-2017 08:26
12-20-2017 08:26
@Rich_Laue I have my weight loss goal in there. I don't log my food. I did for a while but nothing ever changed. When I got this a year ago and set it up it put my calorie burn goal at 2,707. It has been the same ever since.
12-20-2017 23:45
12-20-2017 23:45
@David_P, since your question has nothing to do with your tracker a hardware, I've moved the thread to managing weight.
12-21-2017 03:27
12-21-2017 03:27
@David_P wrote:I was wondering how Fitbit calculates the calorie burn goal. Mine has been the same since I have had it.
I also have the same goal for calories burned as back in April 2013, when I got my first Fitbit (and was 15 kg heavier / 4.5 years younger). I don’t use the food plan either. My understanding is the initial calorie goal is initially set so as to be more challenging than the standard step goal (10k steps): in other words, you will need more than 10k steps in order to reach your calorie goal.
It’s up to you to adjust it, if you feel like it’s unrealistic / unattainable. I have kept mine unchanged, just like I kept the original step goal (10k) unchanged. I just don’t like changing things . In principle, it should be more challenging than in 2013, because I’m both lighter and older than back then.
Dominique | Finland
