03-23-2017 20:40 - edited 03-23-2017 20:56
Since January 1st, I have lost a total of 13 pounds (I was 128 pounds on Jan 1... 115 pounds today). I got my aria scale in February and have been tracking my weight and body fat - it says I have gone from about 30% body fat (feb 10) to just under 24% body fat (today). My BMI on Feb 10th was 22.6, today it is 21.2.
Should I notice some real weight loss and size change (inches lost)? My clothes fit the same.
At what point should weight loss become noticeable?
Best Answer03-28-2017 14:03
03-28-2017 14:03
Normally its after about 10 pounds. But it doesn't sound like you have a lot to lose. So it might take a bit longer.
Do you do any kind of exercise as that help as as well
Wendy | CA | Moto G6 Android
Best Answer03-29-2017 02:47
03-29-2017 02:47
It’s hard to believe you could lose 10 per cent of your body weight without noticing it in the mirror and with your clothes fitting the same. Surely if you had tight jeans, they should feel a bit loose. It can be hard to see changes in oneself (since we’re seeing ourselves everyday), but someone who hasn’t seen you for a while would probably see a difference.
What’s your exact goal? Your BMI was slightly above the mid-point of the normal weight range, now it’s slightly under. In other words, you’re still a very normal weight person, just a bit thinner.
Dominique | Finland
