07-28-2017 09:04
07-28-2017 09:04
Hello, all! My long-term goal is to lose 125 pounds (down 28 so far!). Since that is a daunting task, I have broken that down into short-term goals based off of my BMI (I'm 5'6"). My BMI is currently considered Obese II. My short-term goals are to make it to 214 lbs, which will have my BMI in Obese I; then 185 pounds, which will have my BMI in Overweight; and then 150, where I will be at the top number of my "ideal BMI." I've set my goal weight as 150 on the FitBit dashboard, but I wish there was a way to show the short-term goals as well, or tailor the badges to mark the accomplishment of meeting the short-term goals. Those numbers are now ingrained in my mind, so I don't need FitBit to keep track of the goals; however, anyone who has ever tried to lose weight knows that every little bit of encouragement helps. Does anyone know of a way to do that that I may be overlooking? Thank you for any help you can provide!
07-28-2017 09:23
07-28-2017 09:23
You'll need to change your Fitbit goal to match your ST goals. It's probably smarter to do that instead of the big picture anyway.
07-30-2017 17:47
07-30-2017 17:47
First, congrats and high five on your losses so far! you can for sure keep adjusting your weight loss goals to the increments you mention in your post. I am an all or nothing sort so I would leave it at my ultimate goal and keep plugging away. whatever you decide to do- much luck in your journey
Elena | Pennsylvania
