Hi @Pebbles_2009 - I’m moving your post to the Manage Weight thread in the Wellness Community. You are much more likely to find like minded folk there. Good luck with your efforts!
How do you plan to do it? It would be 36% of your starting weight, which is quite a lot. You’d probably want to split it between several phases of active weight loss, with maintenance phases in-between (as opposed to doing it in a single, uninterrupted stretch of loss.
Dominique | Finland
