03-24-2016 17:36
03-24-2016 17:36
Best Answer03-25-2016 02:42
03-25-2016 02:42
Looking at your profile, I indeed see quite a few active days at around 15k steps, but there are also a few days (eg. the last two Sundays) with really low step counts (< 2k):
I understand no one can (or should) perform intense physical exercise seven days a week, but why not add one hour of walking on your low-step days? Walking is a great calorie-burning activity that will not lead to overtraining.
As to your belly fat and the top of your thighs: unfortunately, you cannot "spot-reduce" fat. In order for fat loss to occur, you need to be in a reasonable calorie deficit. You may not lose fat primarily where you want to: the areas you mentioned are known to be the ones where "stubborn fat" is stored.
Since you are closer to your ultimate weight goal, weight loss is going to be slower than when you were 40 pounds overweight. To your advantage, you’re taller than average and young, which means you have a higher metabolism than most females. This means you can eat a decent amount of food while still being in a deficit.
Dominique | Finland
03-25-2016 02:42
Dominique | Finland
Best Answer03-25-2016 06:29
03-25-2016 06:29
Best Answer03-25-2016 13:00
03-25-2016 13:00
OK, I wear my Fitbit 24/7, and I assumed you would as well. I think it’s a good idea to do it if you want to have a clearer picture of your total expenditure on a weekly basis. Especially if you want to lose weight. The Fitbit mobile app makes it easy to follow up total weekly calories:
Dominique | Finland
