10-17-2014 01:14
10-17-2014 01:14
I know I've been doing extra runs and walk. But the weight loss, is it even safe?
Best Answer10-17-2014 03:08
10-17-2014 03:08
Better slow down on the weight loss its a lot quickly slower is better
Best Answer10-17-2014 07:39
10-17-2014 07:39
it depends on how much you have to lose. if you have a lot to lose, it's probably ok as long as it doesn't happen all the time (if you just started dieting, a good chunk of that 17lbs may just be water weight).
If you don't have a lot to lose, then 17lbs in 2 weeks is pretty drastic. did you do anything differently those 2 weeks? be as specific as you can. finally, if this is completely not normal for you and you're concerned, why not just make an appointment with your doctor? it couldn't hurt and it'll be much more definitive than any answer you will get here on the forum.
