11-08-2021 11:56
11-08-2021 11:56
To all the native English speakers here, could you please help me with the following questions (quite important in the calories count context):
1) What is the difference between "portion" and "serving"? To me, this seems to be synonymous, meaning the amount you eat in one sitting.
2) Any idea how the serving/portion size is estimated in the available Fitbit calories tables?
Out of necessity, I am using the British tables since my German is not that good and there are no tables for my area. Here I have run into the following mystery while attempting an educated guess of calories in a serving (about a tablespoon) of homemade sour cherry jam:
Two brands of sour cherry jam listed, both with about 244 calories per serving (good, means that homemade may be in a similar range). From available net data, these values, however, refer to 100 g of the jam, so is this really supposed to be one serving?
I suspect that some of the numbers in the tables may be more than a bit off.
Best Answer11-08-2021 16:28 - edited 11-08-2021 16:29
I have not used the food tracking so not sure this fits right, but I would say a serving is a fixed amount for that food, perhaps one slice of bread; but a portion is how much you eat at one time. For instance maybe I make 2 full sandwiches using 4 slices of bread. In that case, the portion would be 4 slices, equal to 4 servings but still my portion. And your portion could vary at different times, but a serving is a set amount.
Or I could fill my plate with mashed potatoes. The plateful is my portion, but it might amount to several "servings".
Best Answer11-09-2021 13:08
11-09-2021 13:08
Yes that would make sense - except that the serving sizes listed in the tables appear to be totally arbitrary and unrelated to what anyone could consider a portion. See my cherry jam example: the only way how to find out my actual consumption is googling up that jam' s calories per 100 g and only then can I find out that serving in this case means 100 g. No idea if that jam' only comes in 100 g glasses. An even wilder example is butter, with calories per serving varying between 35 and 744, the later obviously being per 100 g.. Why can't serving size be listed as well?
Best Answer11-10-2021 14:45
11-10-2021 14:45
I am not sure I fully understand the question, but the jelly, butter or whatever you are eating should come with nutrition information on the label with serving size and calories spelled out. When I was logging food, I would actually work in reverse. I would look up what 1 gram/ounce of something was and then figure out how much of that I can eat. So for example.. 1 ounce of broccoli is 9 calories. I wanted no more than 50 calories of my dinner to be taken up by broccoli so I would eat 5 ounces of broccoli weighed on a scale. I would log all the items I ate often as my favorite food so I had the calculations available to me each time. Not sure if this helps, but here it is.
Elena | Pennsylvania
Best Answer11-12-2021 22:34
11-12-2021 22:34
Well, that would assume that I am only eating food that comes with labels on it. I am definitely sure that I am not going to restrict my diet in this way. What I am missing iare more generic entries with values per weight or volume as opposed to per a mysterious, company or country- specific serving. For example, try to look up milk in the tables - you won' t find how many kcals are in 100 ml of full fat or skimmed milk, only in a portion of Tesco milk!
