09-23-2019 09:50
09-23-2019 09:50
Starting to really try and track my food to lose weight. I have used Myfitnesspal for a long time but my husband said that my Fitbit app did the same thing but also tracks all my daily activity. Any suggestions?
09-23-2019 11:12
09-23-2019 11:12
The respective apps can be linked, so your calories out from Fitbit can be used by MFP and your calories in from MFP can be used by Fitbit. It’s therefore up to you which one you use to track your intake. If you’re already familiar with MFP, maybe the easiest is to continue to use it: just link it to Fitbit so Fitbit knows about your intake.
Dominique | Finland
09-24-2019 06:41
09-24-2019 06:41
I actually use the fit bit app more, but the bonus to MFP is that you can create and save your own recipes.
10-02-2019 11:45
10-02-2019 11:45
How do I create a link?
Thx
10-02-2019 14:24
10-02-2019 14:24
@ki6avf wrote:How do I create a link?
Check these instructions.
Dominique | Finland
10-02-2019 15:03
10-02-2019 15:03
10-08-2019 00:12
10-08-2019 00:12
Use both. MFP has a bigger database and using both gives you added options to keep better track of everything. My Dr. recommended MFP be used with my Fitbit and that was good enough for me.
