@marymouse wrote:So I always thought eat less calories than you burn lose weight. Calries in vs calories out. I am not losing weight. I am 51, premenopausal and obese. Why am I not losing weight.
It is, can't escape the law of thermodynamics.
But your estimate of either side of the equation can be off, or a little of both.
How much do you want to loose, and how aggressive did you make the goal?
How long not losing weight?
Did you start doing exercise at the same time?
What is the exercise, and do you manually log the non-step based exercise that Fitbit can't estimate calorie burn well?
Are you weighing all the foods that go in your mouth, and measuring only liquids?
Calories is by weight, not volume. 4 cal per gram carb and protein, 9 cal per gram of fat.
Nutrional labels that give volume are for convenience, and are not accurate, as well as packages usually contain more than stated - weigh everything.
There are really three choices from any given starting point:
1) Eat less calories while maintaining the same level of activity
2) Exercise more (increase level of activity) while eating the same number of calories
3) Eat less calories and exercise more (the little of both category).
First, losing weight shouldn't be seen as something that is a race to a value on the scale. It is just a number.
Although I lost 81 pounds, it hardly happened overnight ( just as putting on weight hardly happened overnight).
In 2007, I reached my maximum weight of 252.
In 2008, I dropped in weight to 214 pounds with no real coordinated plan. Yes, I walked, but didn't measure it in detail.
In 2009, I gradually gained some of that weight back. I was back up to 232 by 12/31.
In 2010, I lost ll fo 4 pounds in 3 months. I joined a walking "challenge," bought a pedometer and measured my stepson a daily basis to record in the challenge. No major changes in diet. I gave up or reduced a few things (I gave up carbonated soft drinks). By July I was down from 228 to 200 pounds. By the end of 2010 I was at 190.
In 2011, my weight was at or near 190...all year. I did gradually increase my daily step count so that I was averaging 20,000 steps per day but my weight was "stuck." Now my body was changing. I dropped inches, not weight.
In 2012, I added MyFitnessPal to my phone and began tracking my food much more closely and did a step change in my activity level (22,000 steps/day...that was more of a challenge in time than I thought). My weight dropped through my initial target of 179 by September and to my final target of 173 by Thanksgiving 2012. I bought my first Fitbit in June 2012 and linked it to my MFP account.
I bought a scale sometime during that year to measure more accurately than I had. I found out that my calorie intake was higher than I had estimated.
I finally flipped my target on from losing weight on MFP to maintenance. My weight kept falling and dropped all the way down to 165. I was still maintaining 20,000 steps per day.
When I took up running again in April 2013 in addition to walking, my overall steps dropped but I was using different muscles than walking. As I added miles and calorie expenditure, my weight actually increased and stabilized at 169-171 pounds...which is where it is today.
It took 5 years to get my weight back down to where it had been years before. I've been maintaining it for 1-1/2 years. Not a race, but slow steady progress.
If you work at it. It will come. No matter what, you cannot avaoid the laws of thermodynamics. You can, however, have challenges from your body that seem to defy them.
What an inspirational story, S Trooper, thanks for sharing.
I appreciate your saying this is not a race and that it's worthy just to keep on getting more fit.
I feel stronger, my muscles are tighter, the other day I tripped on concrete and just got up, was not hurt at all. Knee banged a bit, did not need Advil.
So it's good, despite what the scale says. Need to remember that.
You should put your story up where everyone can see it in shared stories.
