01-21-2014 12:55
01-21-2014 12:55
I've had my fitbit since Christmas but been very careful with exercise and food and now I'm 2 pounds heavier than when I started.
Help!
Best Answer01-21-2014 13:09
01-21-2014 13:09
Check your measurements. Are your pants getting looser? Muscle is more dense than fat so you might be building lean mass with or without losing fat mass. Although it is technically/scientifically possible to lose fat while gaining muscle, most people don't seem to be able to do this (no one knows why exactly) and so your body will do one and then the other over and over. At this point you might be building lean mass (which is what you want in the long run anyway) and your body just hasn't revved its metabolism up enough yet to start burning fat fast enough. If this is happening you will notice your clothes are too big and people are saying 'you look good' but the scale will be stuck or even go up.
Best Answer01-21-2014 13:14
01-21-2014 13:14
Thanks for your reply. They did start to feel a bit better but then went back to being tight. I think I'm confused by how much I should be eating. The calories intake vs output always says I'm under and on the log page it always says I have so many calories left to eat. Am I supposed to be eating all the calories or I was thinking of just limiting calories to 1200 a day. I have the weight loss setting to kinda hard which is -750 per day so is that amount calculated into the amount of calories I should eat?
Maybe not eating under enough?
Best Answer01-21-2014 13:18
01-21-2014 13:18
01-21-2014 13:27
01-21-2014 13:27
Don't be kicking yourself for the weight gain. You know certain times of the month a woman does retain water and that can account for those two pounds.
You're on the road to more steps and becoming more aware of your active levels. We're here for you and for a better life for us all.
I log everything I eat to keep track of it. It shows me I'm not eating as much junk as I used to and am getting more veggies, which is a good thing. Maybe writing down your food will help you as well.
Also, be sure you drink enough. Sometimes being thirsty, we get confused and think we're hungry.
Many threads on how people have done better, even after slipping. So don't you worry. Just take a deep breath and start again.
Best Answer01-21-2014 15:54
01-21-2014 15:54
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answer04-02-2014 17:36
04-02-2014 17:36
Hi all. I, too, have been frustrated lately about no weight loss. Here's my story. I walked WAY less January-early March due to snow, ice and cold and ate fairly normally. I log in what I eat almost everyday and eat very healthfully (olive oil, fish, almonds, apples, carrots, spinach, protein). Just last week, with last of snow, I started ramping up my walking, over 10,000 steps a day and I feel terrific!
Yes, I am disappointed the scale has not move SINCE FEBRUARY, not an iota, but I suspect it will. I've decided it makes no sense to cut back on food, I will just be miserable.
Best Answer04-02-2014 22:20 - edited 04-02-2014 22:24
Did you select a weight loss goal in Fitbit?
Then you should be eating to your goal, which already has a deficit in it to cause weight loss.
You do more, you eat more, you do less, you eat less. Keep what is hopefully a wise choice of deficit in there the same.
How well do you log your foods?
Do you weigh everything but liquids?
Calories is based on weight, not volume, so measuring can be very inaccurate, as can package nutrition labels - "about 2 servings" could be 2.5 to 3 when you actually weigh the package and divide by grams in a serving.
Do that all day long, you got no deficit to lose weight.
I'll bet either your logging is really bad, or it's pretty good and you are eating way too under already and your body has adapted down, burning less than Fitbit knows.
Sadly, whether a small deficit or big deficit, you aren't building any muscle. Men in a study eating at maintenance and new to weight lifting, so the most improvement, only traded fat for LBM (not even muscle mass, they didn't test how much actual muscle mass) at the rate of 3.5 lbs in 16 weeks, less than 1 lb a month.
If you are a woman eating at a deficit, and not lifting - forget it.
http://jap.physiology.org/content/76/1/133.short
Best Answer04-03-2014 05:59
04-03-2014 05:59
I am also having the same problem. I am using the calories that fitbit says I have and sometimes not all of them. I'm only into this a week. I am very honest about what I'm eating and drinking. Hopeing I'm building muscle. I am walking 3 to 4 miles a day plus my normal activity. Just want to see at least 1 pound gone.
Best Answer04-03-2014 08:54
04-03-2014 08:54
@Tamilm wrote:I am also having the same problem. I am using the calories that fitbit says I have and sometimes not all of them. I'm only into this a week. I am very honest about what I'm eating and drinking. Hopeing I'm building muscle. I am walking 3 to 4 miles a day plus my normal activity. Just want to see at least 1 pound gone.
Sadly no you are not building muscle. You've likely been walking for years, so there's no need for more muscle as if you are overloading what you've got.
But there is a need to power you longer now, so the boy is going to add more glycogen stores in the muscles, which stores with water. 500 cal worth stored is 1 lb.
With so little to lose, hopefully you selected to lose little, or you'll have a fight on your hand. Just meet your eating goal. It's a goal to reach, not miss. You wouldn't stop before reaching your weight goal, right?
Best Answer04-03-2014 09:15 - edited 04-03-2014 11:33
I'm not sure what you're trying to tell me
Best Answer04-03-2014 10:45
04-03-2014 10:45
Probably going to want to edit your message fast and delete personal contact info.
I'm not sure what part of what I said is confusing.
You hoped to be gaining muscle by walking - no a chance.
You have 1 lb to lose - select the lowest weekly goal loss, like 1/2 lb weekly.
