02-03-2015 06:51
02-03-2015 06:51
Best Answer02-03-2015 07:03
02-03-2015 07:03
Fitbit will calculate how many calories you are burning by just being alive and so that will show up. When you get up in the morning, it will say you've burned X amount, and that is simply just what your body burns naturally. When you're walking, or moving around lots (running, or step based activities) it will notice and calculate that you are burning more, so the calories burned will be higher. If you do any non-step activites (most gym stuff) then it won't know so you will need to manually imput those, and then that will show up as calories you have burned.
Hopefully that helps!
Best Answer02-03-2015 07:13
02-03-2015 07:13
02-03-2015 07:03
02-03-2015 07:13
Best Answer03-31-2015 06:52
03-31-2015 06:52
If i do a circuit training workout which I do most everyday about a 1/2 hour to an hour with weight resistance, how do I know how many calories I burned? If I just put the amount of time i completed in activities will Fit bit add that?
Thanks
Tracy
Best Answer03-31-2015 08:55
03-31-2015 08:55
When you put in your activity and the amount of time you did it, then FitBit will calculate calories burned for you. Just be sure that your weight logged into FitBit is accurate. For example: a 130lb person will burn a different number of calories doing 30 minutes of crossfit than a 210lb person doing the same thing for the same amount of time traditionally.
Hope this helps!
Joy
Best Answer08-05-2015 19:20
08-05-2015 19:20
Can you manually input exercise on a Flex? If so, how? I see "Track exercise", not log it. How doe that work? I do elliptical and zumba as well as pilates. Does the Flex pick that up or can I enter it?
Best Answer08-09-2015 03:29
08-09-2015 03:29
Best Answer08-09-2015 17:46
08-09-2015 17:46
@Tracy-15 wrote:
Where you log your food is a tab for activities. That is where you log your exercise. If i am walking I don't log it as it will double count it.
If I do my total gym etc. I take off the fit bit during that and then will log it manually. If the activity choice is not there, I google "how many calories burned doing ....... I can usually find how many calories burned for the time I did that activity.
It won't double count unless you're inaccurate when entering the start and stop time for the activity. Manual activiy entries override the automatic tracking, so the only way it will double count is if you override the wrong data by entering the time wrong.
What I do when I'm using a treadmill at the gym is take a picture of the screen when I finish. My phone (iPhone 6) time stamps the picture with the time I finished, and the treadmill display shows the duration of the exercise. So if my picture is stamped 6:55 and my workout lasted 47 mminutes, I know the start time was 6:08.
If I'm lifting, my app has an area for notes, so I just add the start and stop time for that and enter the exercise manually when I get home.
