08-01-2015 02:43
08-01-2015 02:43
The weight logging page is giving me trouble. It isn't loading properly and wont display graphs and wont let me log previous weights. All other features work just fine. I'm on chrome.
Best Answer08-02-2015 12:39
08-02-2015 12:39
08-01-2015 02:49
08-01-2015 02:49
I've tried on internet explorer now as well. Still have the same problem.
Best Answer08-01-2015 14:56 - edited 08-01-2015 14:56
Mine worked, and I'm using Chrome. I added a weight from before I bought my Fitbit, let alone created a profile.
Are you trying from the very bottom of the Log > Weight page or from somewhere else?
08-02-2015 05:35
08-02-2015 05:35
On of my computer geeks have told me that internet explorer is going to be going away. So when I heard this I switched to google chrome. Now my Fit Bit does everything it is suppose to do and works fine.
08-02-2015 05:54
08-02-2015 05:54
Best Answer08-02-2015 09:27
08-02-2015 09:27
You may have to call customer service. All I do is scroll down to the bottom of the Log > Weight page on my laptop, enter the weight and click on the calandar to select a date.
08-02-2015 12:39
08-20-2015 01:52
08-20-2015 01:52
Doesn't work for me. I can't even click in the calender box to choose a date (in Chrome). The log button seems to work but it doesn't get logged, and I see no graphs. The dates that I managed to get in was via my android app.
Best Answer08-20-2015 03:47
08-20-2015 03:47
Best Answer08-20-2015 04:29
08-20-2015 04:29
Best Answer08-20-2015 04:31
08-20-2015 04:31
Best Answer09-01-2015 07:36
09-01-2015 07:36
Changing the region from Norway to US solved my issue with not being able to add my monthly weight logged as well. It's not a perfect solution, but it will do for now.
09-01-2015 09:14 - edited 09-01-2015 09:16
I'm having the same problem today (9/1/15). Did not have a problem yesterday.
I've made the same observation as klaartje.
Best Answer09-16-2015 05:06
09-16-2015 05:06
I have the same issue... Can't logg my weight since a few days ! Tried changing the country, as suggested, but it didn't work for me....
Best Answer02-19-2016 09:33
02-19-2016 09:33
I've been unable to log weight for the last 4 days, and I am now and always have been in the United States. I can't enter anything in the date field. I have been able to log activities. This forum is so disorganized I couldn't find any recent entries with this problem (or anyone in the U.S. with it.), but my page looks just like the screen shot above.
Best Answer01-27-2017 07:57
01-27-2017 07:57
Have you tried 70.8 instead of 70,8? So a point instead of a comma.
Best Answer01-27-2017 08:20
01-27-2017 08:20
Do you use the app or mobile dsktop? The app works very well on Android, and I have an older phone, Samsung Note 3. I like logging food on the desktop, a little easier, but not hard on the app. Also... I know it is expensive, but the Aria scale reports into the app for you. I just recently bought one, and I am glad that I did. Seeing the %bodyfat is more motivating than the weight number.
Good luck!
