08-28-2016 20:18
08-28-2016 20:18
Well it's been a short while since I've posted here, but wanted to update: I started dieting/exercising in ernest on March 10. I got my Charge HR on March 27th, then replaced it with a Blaze about a month later. Results are 39 pounds of weight loss (267.4 to 228.4) at a rate of 1.6 pounds per week, with my goal weight (210) a mere 18.4 pounds away!
I'm following my Fitbit app's reccomendations to the letter - especially how much to eat. The only weakness in the Blaze is inaccuracy with heart rate while exercising, although it is very accurate while resting.
Following the program has:
The device has some quirks, but it is a great tool for fitness and weight loss.
08-28-2016 23:33
08-28-2016 23:33
This is great, kudos to you! What kind of exercising have you been doing? Do you intend to keep the same deficit for the remaining 18 pounds? Asking as it is commonly advised to use a smaller deficit as you get closer to your target weight.
Dominique | Finland
08-29-2016 06:08
08-29-2016 06:08
@Dominique, Thanks for your Kudos!
My exercise of choice is walking. I'm walking an average of 18 miles a week (6 outings, usually 3 miles each) and my speed is slightly faster than 3mph (a little over 19 minutes per mile according to the tracker). I'm pretty much the slowest walker on the paths, but that's ok - my goal is a heart rate number, not speed. ![]()
Yes, I'm going to try to maintain 1.5 lbs weight loss per week all the way to goal. However, if the weight loss rate slows down I won't be disappointed.
08-29-2016 07:17
08-29-2016 07:17
You have done excellent congrats!
Wendy | CA | Moto G6 Android
08-29-2016 08:25
08-29-2016 08:25
@WendyB -- Thanks!!
08-29-2016 10:17
08-29-2016 10:17
Way to go!! keep up the excellent work!
08-29-2016 14:42
08-29-2016 14:42
Adding my congrats here as well. An excellent example of slow and steady wins the race. Best of luck on those last few pounds.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
08-30-2016 18:27
08-30-2016 18:27
@JamieS_Wisco, @A_Lurker Thanks for the encouragement!
09-01-2016 11:19
09-01-2016 11:19
awesome. Congrats to you! I was happy to see that you acknowledge that a slow down may occur and you won't be discouraged. You may want to think about increasing calories out or decreasing calories in to avoid a slow down that becomes a problem. Now is also the time to think about your maintenance plan. Sometime losing is easier than keeping off. You are doing so well- you should be very proud of your accomplishments and thanks so much for the update.
Elena | Pennsylvania
09-20-2016 06:35
09-20-2016 06:35
Update: Another 3 pounds lost. Still 1.6 lost per week, weight 225.6.
Weight lost? 41.8
To go to reach my goal: 15.5
Almost there! Thanks Slavedriver! er -- I mean Fitbit Blaze!
09-20-2016 06:37
09-20-2016 06:37
Thanks for the encouragement @emili
09-20-2016 11:56
09-20-2016 11:56
Thank you so much for sharing! It helps knowing it is possible and you have done it and it works. Keep us posted.
Best Answer09-20-2016 14:35
09-20-2016 14:35
@Noir, thanks for the encouragement!
09-22-2016 06:10
09-22-2016 06:10
Woo Hoo on more loss!
Best Answer09-28-2016 07:05
09-28-2016 07:05
great success story! Please keep coming back with updates! Reading about other peoples success keeps me motivated to hit my own goals!
