Hello @TJBake23
Since you're having issues with updating/adding your current weight in the Fitbit app, you might see if you can use the fitbit.com dashboard to do that.
I'm not sure if the Fitbit app is immediately updated after you make changes from the fitbit.com dashboard. Once your current weight is correct in the app, you should be able to set your weight goal.
