Weight loss Plateau
ANSWERED
Hi everyone! My name is Trudy and I am new to fitbit... well.. I am actually new to this whole "life change" thing. Long story short I am a working mother of 4 and after having my last son my total weight gain was about 40lbs. I was, needless to say, disgusted. For months I talked about making a change and one day I finally woke up and decided to do it. So far I have lost a total of 21 lbs. I am COMPLETELY changed the way I eat, drink. exercise, and live. I was averaging about a pound a week. I do spin class twice a week and exercise on my lunch breaks for a total of 4 days a week. On Fridays I will go to my gym and do the eliptical for about 27 minutes. My weight had been at a stand still for 3 weeks! I wanted to take a hammer to my scale. I plan on increrading my workout times as much as I can, but with 4 kids and working that is hard to do. Any other tips on what I can do. Thanks in advance!
1 BEST ANSWER
Accepted Solutions
Hi Trudy, the first thing you find out is the closer you get to your goal, the harder it gets.
Since you said you changed your diet, are you logging all of the food you eat, and running a either a 500 or 250 calorie deficit?  I'm guessing you are since you said you were losing around a pound a week.
80% of weight loss is your diet.  So if you are not logging your food, that's my first suggestion.  Then setup up a weight loss goal.  For 20 lbs or less, a 500 calorie deficit is recommended.  Once you get to 10 lbs or less, switch to a 250 deficit.
My second suggestion is try to find time to work out every day.  And to do a different kind of work outs each day.  Spin class, cardio class, walking, running, cycling, hiking, swimming are just some of the things you can do.  Changing things up makes your body not prepared to burn the same calories each day. Sometimes when you do say 30 minutes on the bike every day, your body will decide ok, I need to reserver 500 calories at 5:00 PM.  So it will burn 500 fewer calories doing things like breathing, keep you warm, pumping blood...  So you think you burned 500 calories on the bike, but I reality, you burned nothing.  By changing things up, you body doesn't know what to set a side, and you burn more calories exercising.
If you can get your exercise times to 30 to 50 minutes each day that will also help too.  I exercise 90 to 120 minutes every day (when I wasn't injured and sick with strep, flu, cold, bronchitis, and now an infection).  I've lost 59 lbs in the last 8 months.
But I know, 4 kids is going to make that VERY hard to do.  They come first....
Have you taken your measurements lately.  A lot of people gain muscle, and lose fat at the same rate.  So their clothes get looser, but the scale is unchanged.  But then they notice their stomach is 1/2 an inch smaller.
Your body is tough thing to control.  How much you eat, and how much you exercise, sometimes cannot over come it's desire to get back the weight it was happy at.  You weren't happy, but it was.  And it wants to get back there.  So once you get to your goal, it doesn't stop there.  You have to keep monitoring your weight, and keep exercising so you don't go back.  Eventually your body gets to accept your new weight as normal.  But sometimes that can take YEARS.
Bottomline to break a Plateau, one must eat less, exercise more, or both.  Just make sure you don't eat less than 1200 to 1300 calories a day.  When you do that your body really holds onto fat as much as possible.
Good luck and keep active!
John | Texas,USA | Surge | Aria | Blaze | Windows | iPhone | Always consult with a doctor regarding all medical issues. Keep active!!!
9 REPLIES 9
also, your body might be telling you that the weight you are at is good for you.
You're on the right track Trudy.
JohnRi makes some good points - but there is one area, where although the conclusion is correct - the way it's worded may leave some folks with more questions than answers.
"Changing things up makes your body not prepared to burn the same calories each day. Sometimes when you do say 30 minutes on the bike every day, your body will decide ok, I need to reserver 500 calories at 5:00 PM.  So it will burn 500 fewer calories doing things like breathing, keep you warm, pumping blood...  So you think you burned 500 calories on the bike, but I reality, you burned nothing.  By changing things up, you body doesn't know what to set a side, and you burn more calories exercising."
The end result, yeah, your body doesn't burn as much. But, what's really happening is our bodies are extremely adaptive. You cycle at a comfortable or consistent pace for 30 minutes a day (or 27) - and your body gets used to it. The cycle's statistical readout has no idea that you've ridden for the same workout for the past month. So - both the Fitbit and the cycle tell you that you've burned off X calories.
The problem is - your body has adapted. You might still feel like you did a great workout - but your body, although still tired, isn't getting the same benefit.
Imagine that graph from high school or college - the one they call the law of diminishing returns. Because of our adaptability, if we don't progressively increase the difficulty of our workouts every 4 to 8 weeks (I believe 6 weeks is the sweet spot) then our bodies won't respond the way we'd like.
Try riding your bike for 24 minutes - but get those legs really moving every 3 minutes for 60 seconds.
Regular pace 3 minutes
As fast as you can go for 60 seconds
Regular pace  (no coasting!) 3 minutes
As fast as you can - at least 120 revolutions per minute
Then - the next time - reduce that time of regular pace to 2.5 minutes.
If you can go through the 3 mins regular, 1 min fast  for 6 times - that'll save you 3 minutes and you'll have worked a lot harder. You may need to 5 min regular and 30 seconds as fast as you can when you first start - but your legs will communicate how confused they are and probably rebel at first. Just show them who's boss. They'll figure it out.
Those who have no idea what they are doing genuinely have no idea that they don't know what they're doing. - John Cleese
Wow! Thank you so much for taking the time and giving me so much good information! Also, congrats on your weight loss! That is inspiring! Yes I log in my food daily. I have replacement my breakfast and lunches for AllMax Isoflex Protein Shakes. After posting I explored my fot bit more and noticed I had the calories on a setting where it really gave me to many. I have since readjusted that. You are right. I do need to find to everyday. I have some weights at home for my arms so I can always do that and cardio at home if I can't make it to the gym for some reason.
^^ Never thought about it like that before! I mosr def need to switch it up!
If thats the case my body can shut the crap up lol
Thank you so much for the advice! I never knew how hard and diffcult our bodies can be until I made this change. The only cycling I do really is spin class which is intense. I do body pump class 2 times a week. I gues my next step will be getting someone in there and showing how to use all those machines.
Hsppy Stepping!!
Most of this post is utter nonsense.
A 500 calorie deficit (1lb/week) is just fine right up until your goal weight. Make sure to get adequate protein and engage in resistance training to maintain the muscle you have.
Yes, the body becomes more efficient at doing exercise over time. However, 30 days is no where near soon enough for this to take place and under no circumstance would 500 calories be negated in that span of time. Where is this phantom energy coming from? Sounds like your body is a perpetual motion machine.
Exercise will increase your caloric deficit, speeding up weight loss and/or allowing you to eat more. Thats all. It is good for overall health and should be done for that reason alone.
Its very debatable if muscle can be gained in a caloric state. Most researchers dont believe its possible. Muscles may increase in size due to water uptake and strength gains are largely attributable to CNS adaptation ("noobie gains").
Under no circumstances does the body have a mind of its own with respect to weight gain. Unless you have a disease, its a simple formula of calories in vs. calories out. Set point theory, as you describe, is also very debatable. Keep in mind that progress should be tracked over time and weight loss isnt linear. Dont make any changes for 2-3 weeks.
It is recommended that women eat no less than 1200 calories a day without the advice of a doctor ONLY because it becomes difficult to recieve adequate micronutrition below that point. "Starvation mode" is a myth.
My advice is to double down on your diet by weighing everything you eat (including cooking oils, etc) to the gram on a food scale. Track your calories and ensure you are 1000>x>500 calories below your TDEE. Swings in sodium, activity level, and fiber intake can cause water retention, and water retention can mask weight loss for quite some time. Increasing water intake will help with this.
I disagree with you. JohnRi is right. Our bodies are complex machines and a simple "calorie in calorie out" is not the solution to weight loss, although it does form a big part of it.
