02-02-2014 03:37
02-02-2014 03:37
When I first set up my weight loss goal, I entered a weight loss goal per week however I would like to change it. Can anyone tell me how to do this?
Best Answer02-02-2014 12:17
02-02-2014 12:17
On the dashboard there should be an icon on the left side (near the top) that has 3 lines through it. Click that and see if there are any additional tiles available to add. Also, are you using the old dashboard or the new tile based one?
Best Answer02-02-2014 07:23
02-02-2014 07:23
@Neece_newf yea go to your Calories In vs Out tile
and click on the gear icon (bottom left)
from there click on the pencil icon and you can edit your goals.
Best Answer02-02-2014 11:54
02-02-2014 11:54
Thank you for responding. I do not see the tile for Calories in Vs Calories out. Where do I go to see it?
02-02-2014 12:17
Best Answer02-05-2014 11:56
02-05-2014 11:56
It worked....thank you!!!
Best Answer08-10-2014 15:26
08-10-2014 15:26
You half to go to your dashboard, then click on add to dashboard at the side of your screen and find the Calories in Vs Calories out
@Neece_newf wrote:Thank you for responding. I do not see the tile for Calories in Vs Calories out. Where do I go to see it?
Best Answer03-02-2016 08:29
03-02-2016 08:29
I have a question about weight loss goals... I have recorded my total weight loss goal , however I feel like I should record the goal month to month, so I will not get discouraged. Can anyone recommend which way works best for them?
Best Answer03-02-2016 17:44 - edited 03-02-2016 17:49
Here's what's working for me.
I decided to use just two weight loss goals for myself. The first is 43 pounds, from 228 down to 185. When I hit that one, or shortly before, I'll decide how much farther I want to go based on how I look and feel at 185. I use the weight loss chart to keep myself motivated; I love seeing that sloping line get closer to my goal each month, and I think if I changed my goal frequently I'd miss out on that motivator.
I also created a Google Spreadsheet where I included a sloping line for my 1 pound per week target. At this point I'm six weeks ahead of target and that's the chart that really makes me feel good. 🙂
Charge HR, Flex | Windows 10 | Android | iPad
