09-02-2015 23:33
09-02-2015 23:33
I notice that that although the reading from my Aria scales syncs correctly to the FitBit dashboard the weight tile gives an incorrect "weight loss to go". My original weight was 14 stone 8lbs and I set a goal of 14 stone 0lbs. Today the Aria tells me I weigh 14 stone 3.2lbs, but the weight to go shows as 2.8lbs. There is always thiis sort of difference. Is this a bug or am I doing something wrong?
Best Answer09-03-2015 05:43
09-03-2015 05:43
You might want to check further into by clicking on the settings button at the bottom of the tile. It should show you your starting weight and it may have changed from your original starting weight. I noticed mine has done that a few times once I logged a new weight.
Best Answer09-03-2015 05:47
09-03-2015 05:47
Make sure once you click on the setting icon on the weight tile this comes up and the correct starting weight is what you started out with 🙂 hope this helps!
Best Answer09-03-2015 06:02
09-03-2015 06:02
Best Answer09-03-2015 06:25
09-03-2015 06:25
Yes, what you have left "to go" should reflect only what you have left to lose. If you started out with 40 to lose and lost 20. Then it should only show you have 20 left.
