08-07-2017 13:35
08-07-2017 13:35
Nit fir nothing here , as the weight is not my obsession , but why no movement . I am eating very clean , no meat diet . Filled with energy , calorie burn each day is high . I feel and look different , however the scale just doesn't seem to move .
Best Answer08-07-2017 16:59
08-07-2017 16:59
Clean eating and no meat does not necessarily mean you are eating fewer calories. And if you are eating more than you are burning (even though it may be high) you will not lose fat- which is why the scale isn't moving. To lose fat which results it weight loss you have to eat at a deficit. If you aren't then you will still feel better because you are not eating junk and you will change your composition from working out which will tighten you up and change how you look in some spots, but weight loss will not happen. Depending on how much fat there is, your muscles may not show as much as they could. Doesn't mean you aren't strong, fit and healthy.. if you feel good - keep doing what you are doing!
Elena | Pennsylvania
08-07-2017 14:41
08-07-2017 14:41
@gypsyshewolf -- How long has this gone on? Sometimes it is difficult to lose pounds when exercising, because we build up muscles during the exercise. We lose fat, we feel better, we get thinner - but there may be a slight increase in weight because muscle, which is quite dense, is building.
I based this assumption on your statement "calorie burn each day is high" - This is something I have gone through from time to time when I start bicycling.
@gypsyshewolf wrote:Nit fir nothing here , as the weight is not my obsession , but why no movement . I am eating very clean , no meat diet . Filled with energy , calorie burn each day is high . I feel and look different , however the scale just doesn't seem to move .
08-07-2017 16:59
08-07-2017 17:36
08-07-2017 17:36
Best Answer08-07-2017 17:38
08-07-2017 17:38
08-07-2017 17:38
