11-27-2017 08:50
11-27-2017 08:50
How can I change from kg to lbs on my dashboard
Best Answer11-28-2017 16:44
11-28-2017 16:44
Hey @Salemgirl if you are good to go, consider marking Dominique's last reply as the solution. This will help others with the same question locate the answer.. thank you!
Elena | Pennsylvania
11-27-2017 09:45
11-27-2017 09:45
Sure. Just edit your profile and change the unit:
Dominique | Finland
Best Answer11-27-2017 13:33
11-27-2017 13:33
Best Answer11-27-2017 14:25
11-27-2017 14:25
Thx. Tried to edit. Not successful. Working on it.
Best Answer11-28-2017 03:51
11-28-2017 03:51
Since I see you’re using an iPad, you can also do it in the Fitbit app (if you have installed it on your iPad). Just select Account > Advanced Settings > Units and you should see this:
Dominique | Finland
11-28-2017 05:14
11-28-2017 05:14
11-28-2017 16:44
