01-29-2023 01:33
01-29-2023 01:33
So I have a question I'm not good at math but if when I started losing weight I weighed 246.0 and am now at 242.8 how much weight would that mean I have lost so far
Best Answer01-29-2023 02:51
01-29-2023 02:51
3.2.
Your fitbit profile will track it for you though. Go to your dashboard, click the scales, more, then all time. You can scroll down to add data.
Best Answer01-29-2023 06:57
01-29-2023 06:57
I go to your dashboard, click the scales, more, then all time like you siad. I scroll down to add data.
And i go to Goal Progress all it says is this
1.0lbs
lost since 1/28
112.8 lbs to go and this goal is in the bag!
So where does it tell me where I'm losing weight also I use the website not the app
This is all it tells me idk which one tells how much weight I have lost
Best Answer01-29-2023 07:04
01-29-2023 07:04
You probably need to add data for the day you started. You can change the date on log weight, just set it to the day and starting weight and it should show your total loss.
