01-28-2014 06:33
01-28-2014 06:33
What is the weight for a woman that is 65 and her height is 5 feet 1 inch. What is the ideal weight
Best Answer01-28-2014 06:57
01-28-2014 06:57
Here is a weight chart.
http://www.healthchecksystems.com/heightweightchart.htm
But I would ask your DR what they recommend
Wendy | CA | Moto G6 Android
01-28-2014 06:57
01-28-2014 06:57
01-28-2014 06:57 - edited 01-28-2014 06:59
For 5' 11" adult female that would be between 100 - 127 lbs. (That puts your BMI between 18 and 24 which is ideal/normal range.)
http://www.livestrong.com/article/368590-ideal-weight-for-a-65-year-old-woman/
Best Answer01-28-2014 07:36
01-28-2014 07:36
I think 'ideal weight' is the weight you can maintain without having to be obsessed with food, or constantly be on a 'diet'. Its the weight that allows you to achieve you fitness goals, and maintain a healthy body.
