01-27-2016 16:05
01-27-2016 16:05
I've been tracking for a couple of months, and I just noticed that the library entry for coffee has 5 times the calories that other tracking programs, AND it has carbohydrates. WHY? Is the coffee entry with sugar? Then it should say so!!
Coffee should be 1 calorie per cup, no carbohydrates.
So, whoever controls the library entries should change this.
Now I have to go back and fix all my coffee entries, and there are a lot of them.
01-27-2016 17:23
01-27-2016 17:23
You also have the option to input your own custom entry for items whose values you find questionable in the food database. I do that whenever I find incorrect entries in the database.
BTW I just looked up coffee in the database, and it lists 1 calorie no carbs for 100 grams, which is what my jar says.
01-27-2016 19:21
01-27-2016 19:21
Recommend making a custom entry for your coffee.
Good luck
