When I started "upping" my workout a few years ago I was 118 pounds and wanting to get back to my pre-baby weight of around 112. I did cardio and light weight training 5-6 days a week consistently. I ate fewer than 1400 calories a day and after about 6 months was able to get down to around 115-116 but only when I stopped working out so much and that weight loss was quite short lived. Not what I had hoped for or expected. Since that time I have continued and still only eat about 1200 calories a day. I work out 5-6 days a week still and back in October started a new running class in hopes that finally I could find something that would get me to lose weight. It is 30 minutes of very good running teamed with 30 minutes of weight and core work and I do that 2-3 times a week and then supplement at the gym with lighter runs and floor work. I have put on weight during this whole process. And the hardest part of all of this is that my clothes are fitting tighter. The good news is that I have put on some muscle the bad part is that all of this work has not resulted in weight loss/fat loss apparently. I get the weight part (muscle) if only my clothes were getting looser or fitting better. Also, the myth of the "starvation mode" doesnt really apply here as this has been ongoing for several years and at some point the body would shed the weight, right? I definitely have fat to lose and a closet of clothes that havent been getting worn. In any event...all of the records I keep show about 3,000 calories in deficit each week--which would account for about a pound of weight loss each week. At what point do numbers mean anything? Has anyone experienced this and if so, how did you end up shedding the weight. I dont think I am being unrealistic in hoping that all of my work and diligence should account for something...:) Pretty depressing seeing people putting less effort into the whole thing and getting thinner.
Best AnswerYour body is probably not getting enough calories. These seem like VERY low caloric intake. If your body does not have enough energy to fulfill all its functions, you could be in "starvation" mode. This will make it very hard to lose more weight. The solution might actually be to increase calories, but this, only a qualified nutritionist would be able to help you find this out.
Further to this... 112 pounds seems low. You don`t mention how tall you are, and that is an important factor.
There is also the reality that you gave birth. This changes your body dratically. If you really want to get to a healthy weight, consult a nutritonist, because with the amount of exercise you are putting in, its proabably just a question of food intake vs nutrients absorbed vs calorie burned. You might only need to adjust a few little things.
@JRBW wrote:When I started "upping" my workout a few years ago I was 118 pounds and wanting to get back to my pre-baby weight of around 112. I did cardio and light weight training 5-6 days a week consistently. I ate fewer than 1400 calories a day and after about 6 months was able to get down to around 115-116 but only when I stopped working out so much and that weight loss was quite short lived. Not what I had hoped for or expected. Since that time I have continued and still only eat about 1200 calories a day. I work out 5-6 days a week still and back in October started a new running class in hopes that finally I could find something that would get me to lose weight. It is 30 minutes of very good running teamed with 30 minutes of weight and core work and I do that 2-3 times a week and then supplement at the gym with lighter runs and floor work. I have put on weight during this whole process. And the hardest part of all of this is that my clothes are fitting tighter. The good news is that I have put on some muscle the bad part is that all of this work has not resulted in weight loss/fat loss apparently. I get the weight part (muscle) if only my clothes were getting looser or fitting better. Also, the myth of the "starvation mode" doesnt really apply here as this has been ongoing for several years and at some point the body would shed the weight, right? I definitely have fat to lose and a closet of clothes that havent been getting worn. In any event...all of the records I keep show about 3,000 calories in deficit each week--which would account for about a pound of weight loss each week. At what point do numbers mean anything? Has anyone experienced this and if so, how did you end up shedding the weight. I dont think I am being unrealistic in hoping that all of my work and diligence should account for something...:) Pretty depressing seeing people putting less effort into the whole thing and getting thinner.
Sorry, not myth.
http://www.t-nation.com/diet-fat-loss/truth-about-metabolic-damage
http://www.youtube.com/watch?v=2i_cmltmQ6A
And no, the body would not just finally start shedding fat if you were eating too low that it suppressed your metabolism, causing you to burn less than you and Fitbit think.
You have caused your body to have no deficit in place - you are eating at maintenance right now.
That doesn't eventually go away, as if the body gets unstressed about the level.
You'd have to eat even less and less.
So you only eat 1200 in total - with all that exercise?
So if you had to stop the exercise, sick or injured, you'd have to eat, say 900?
How do you feel about a non-exercise maintenance of 900?
Or 1200 with exercise?
Anything eaten in excess will be stored as fat - because you are eating at maintenance.
Sustainable for you?
If it is, then cut calories to 950 to lose 1/2 lb weekly.
If there is room to suppress your system more - you'll fail to lose there too. So you'll have to cut even more.
Ugh, what a life eating so little.
And your body trying to improve with exercise, barely. Body trying to adapt to far too little food isn't going to make improvements that require even more energy it's not getting.
Make sure to read follow up post on this too.
http://skepchick.org/2014/02/the-female-athlete-triad-not-as-fun-as-it-sounds/
Best AnswerThank you both so much for your response. I joke that I would be the only overweight starving African! I do understand the concept of starvation mode but also dont see a lot of hungry people with an extra 10 pounds around their hips. That said, if 1400 calories is supposed to maintain my current weight according to all the charts and I am eating 1200 (which seems reasonable albeit not fun) than how much should I eat to lose weight? What exactly would that calculation be?
I also have been able to maintain muscle mass and build muscle. I have not experienced "wasting" of the muscles as would also be indicative of starving. Not trying to be trite but as you can see I am very discouraged as "calories in, calories out," "necessary caloric intake," and all the other numbers, math and energy put into this havent worked out. Ugh. Would def be interested to hear how many MORE calories you think I should eat a day in order to lose weight. Math be damned! While the rest of the world has to burn 3,500 extra calories in order to lose a pound how awesome would it be if I could eat more calories than I burn and lose weight. I mean I got to my elevated weight by eating more than I burned to begin with so reason would follow that by doing the same thing would only continue to pack on the pounds. 😞
@JRBW wrote:Thank you both so much for your response. I joke that I would be the only overweight starving African! I do understand the concept of starvation mode but also dont see a lot of hungry people with an extra 10 pounds around their hips. That said, if 1400 calories is supposed to maintain my current weight according to all the charts and I am eating 1200 (which seems reasonable albeit not fun) than how much should I eat to lose weight? What exactly would that calculation be?
You are confusing starving, with starvation mode, better known as adaptive thermogenesis, or as the one study calls is, metabolic efficiency.
Been seen even in morbidly obese, the 600-700 lb person that can't move much at all. They can run the whole day calorimetry room measurement, and they accept the fact they'll be suppressing them about the max 20%. So what was a measured 6000 calorie TDEE soon becomes 4800 TDEE, but since that is still so huge, no problem for them eating at 1500 calories. So what was a 4500 calorie deficit becomes 2300, and even less as weight is lost. But still eating enough.
So are you 25, 5 ft, 100 lbs female that is sedentary lifestyle with no exercise?
That would give you a 1400 TDEE, and indeed would mean going down to 1200 to eat and lose weight.
Or did you read the tables wrong, because you are not sedentary by long shot.
I'm not sure why you are guessing at TDEE levels though from a chart, when I'm assuming you have Fitbit since you are on here asking questions.
What does the Fitbit say your TDEE is on average daily looking at typical week?
And do you manually log all exercise the Fitbit is underestimating, like lifting and spin/biking, rowing, swimming?
If you don't, your TDEE is even higher yet.
That is the figure to take a deficit from.
And you must not have read the links and understood where you are at. Might reread what I wrote, and read the link. The numbers do workout, except you've lowered the calories out side of the equation because of the calories in side.
Do you really want to go down the road of trying to lose weight and then hopefully be able to maintain with a system that is suppressed up to 20% slower than a healthy you could be at?
And the recovery is eating more, not to lose weight short term right then, but to allow you to do it long term and actually succeed and maintain. If genetically your body responds fast and hasn't been abused too long it may respond short term too.
Even though your current results indicate you are not in a diet right now, because you are maintaining, I'll bet 2 weeks it is suppressed maintenance. 2 weeks of increased performance in your exercise and feeling better than you know because you've forgotten.
Eat 250 calories more than you eat right now, daily, for 2 weeks.
If your current eating level truly is your potential maintenance, then you would gain one, 1, whole lb slowly over 2 weeks.
Reread that and let it sink in.
If it is potential, then you take a deficit from 1200. Betting that poor food logging means it's actually more you are eating.
If it is suppressed, the first thing your body is going to do is fill up very depleted glycogen stores with attached water.
You would gain fast and/or more water weight in your muscles, just proving you were NOT already eating at maintenance. At least this type of water weight gain is increased LBM, and increased metabolism.
If the first week is fast water weight gain, you start the 2 weeks again, with 250 more than the first week.
So depending on how much you have starved your metabolism down, it could go longer than 2 weeks.
And the hope is at the end your system has recovered to true potential maintenance and metabolism.
Meaning at that point you could then take a reasonable deficit for amount to lose and have a positive effect of fat loss - not scaring your body to death.
Reasonable at this point is indeed 250 cal deficit. Off potential maintenance, likely around what Fitbit is saying.
Best AnswerI need help! I am on a low calorie diet of 1400 cal. since January, 2014, and I started with 165 pounds and now I have 149, but it has been a very difficult time for me. I'm exercising 2 - 3 hours, 5 days a week and I always take one day off to eat more calories, but this last month, I haven't lost any pound! I got my fitbit 2 weeks ago and I know that my activity is even increasing but I don't see any results, I am very dissapointed!! I'm still 18 pounds over!!
@Isabel38 wrote:I need help! I am on a low calorie diet of 1400 cal. since January, 2014, and I started with 165 pounds and now I have 149, but it has been a very difficult time for me. I'm exercising 2 - 3 hours, 5 days a week and I always take one day off to eat more calories, but this last month, I haven't lost any pound! I got my fitbit 2 weeks ago and I know that my activity is even increasing but I don't see any results, I am very dissapointed!! I'm still 18 pounds over!!
1400 calories in total?!
And exercising 2-3 hrs a day for 5 days a week, or 2-3 hrs a week over 5 days?!
And only 15 lbs lost in that entire time?
Did you happen to read the post right above yours? You should, might open your eyes.
You've done this to yourself probably. Now what are you going to do, eat even less and exercise even more?
You aren't going to get much weight, or fat, loss from a damaged body. Oh, you can keep eating less and less and you will start losing again eventually.
But what do you think your maintenance level is going to be when you finally reach goal weight?
1200 calories with all the exercise being done. Which means if you don't exercise that much, you must eat even less.
Will you be able to comply with a maintenance that low, to needing to eat 500 calories less than you could have otherwise?
And anything eaten extra is put on as fat?
This is exactly how a lifetime of yo-yo dieting starts, wasting away muscle mass going for quick loss, making it easier to gain next time, and harder to lose next time. Requiring more and more extreme measures, all the while having a terrible relationship with food and your body.
Not a great life usually.
Why don't you want to follow the Fitbit plans and method?
Best AnswerSorry it took me so long to respond...crazy week. I have read what you have written and visited the sites and have taken it to heart. According to FitBit and the Total Energy Expenditure site you suggested it says I am burning about 2,000 calories a day on my heavy running days. 45 year old woman, weighing 120 pounds roughly with varied activity levels.
So, in order to do the FitBit way and lose a pound a week (the easy way) I would indeed need to do as you suggest and eat 1600 calories a day instead of 1200 on those days. On my light days I would need to eat 1200 as my calorie expenditure is only 1700 calories. I hear you and will try it--:)
Thanks for all your help!
Ps my husband just got his fitbit and lost 4 pounds the first day...eating at jack in the box and just walking lightly on the treadmill. I could kill him!
Best Answer500 is probably on the verge of being reasonable, so really try to hit your eating goal.
50 over is better than 100 below kind of thing.
For your husband, you either can tell him or just know - anyone starting a diet will lose fast water weight.
Glycogen stores not topped off, they store with water.
That will be gained back every time you eat a lot of carbs or when you go off the diet finally.
It's the wedding cake syndrome - "but after preparing all week by starving myself all I ate was 1 piece of wedding cake and gained 3 lbs Sunday morning!"
