01-15-2014 20:12
01-15-2014 20:12
I am 39 lbs away from my goal, but today, the dashboard at fitbit.com says I am .1 lbs from my goal. My goal weight and present weight are correct, and, until today the dashboard "lbs to go" was correct. Does anyone know what happened?
01-15-2014 20:21
01-15-2014 20:21
Mines doing the exact same thing! Except its 0.3 of a pound.. which I wish was right but most definitely isn't.
Best Answer01-15-2014 20:30
01-15-2014 20:30
I also did an hour of ballet today and logged it manually, yet my dashboard is telling me I've only had 11 "very active minutes"... curious..
Best Answer01-16-2014 03:54
01-16-2014 03:54
Best Answer01-18-2014 06:52
01-18-2014 06:52
Mine is doing this also....and I weigh 0.1 lbs on the Dashboard....
Best Answer01-18-2014 21:03
01-18-2014 21:03
Same here. I figure it's a glitch. I hope it is fixed soon.
Best Answer01-19-2014 06:10
01-19-2014 06:10
I noticed my Fitbit One requested me to update it's firmware the other day. (Via Ipad app) Then this dashboard error seemed to appear after it installed. Very annoying and actually depressing when you don't get a true "read" of what's going on with your weight. Please fix this ASAP!
