08-20-2019 00:23
08-20-2019 00:23
I am using fitbit around 2 to 3 months.
but not losing weight ...how about you?
What should i do so that i lose weight
Best Answer08-20-2019 00:38
08-20-2019 00:38
Wearing a Fitbit can inform you / raise awareness about many things, like your activity (or lack thereof), but there’s nothing magical about it. In order to lose weight, you need to be in a caloric deficit, i.e. eat less calories than you burn. Fitbit can help you with both sides of the equation: 1) you can use the app to log your intake (you can also use a third-party app like MyFitnessPal, LoseIt etc. that integrates with Fitbit, if you prefer), 2) you can use the calories burned estimate provided by your tracker. Did you set up a food plan when you started to use your Fitbit?
Dominique | Finland
