01-01-2015 06:34
01-01-2015 06:34
while setting up my fitbit i accidentally deleted the scale (weight) icon. how do i recover that?
 Best Answer01-02-2015 00:58
                              01-02-2015 00:58
@PatKb wrote:
I accidentally removed the weight tile from my dashboard on the Fitbit app on my iPad. How do I restore it?
OK, in the Fitbit app, you need to click on Edit, after which you can tick the Weight icon and press Done.
Dominique | Finland
 Best Answer01-01-2015 08:45
                              01-01-2015 08:45
If you mean you have accidentally removed the Weight tile from your Dashboard, you can bring it back by clicking on the little Tile icon in the upper left corner and ticking the Weight tile:
Dominique | Finland
01-01-2015 16:57
01-01-2015 16:57
                              01-02-2015 00:58
Dominique | Finland
