01-15-2017 13:21
01-15-2017 13:21
Is there a way to display total weekly calorie target instead of daily ? Would be nice to be able to splurge a few days and make it later. thanks
Best Answer01-16-2017 10:16
01-16-2017 10:16
@jtstagman- No, you can't set a weekly target. I think most weight loss tracking focuses on daily (at least the electronic ones). However, on you computer dashboard if you hover over the tile that looks like a fuel tank, then pick the quick view, it will show you your total weekly deficit. You could use this to adjust towards the end of the week.
Anne | Rural Ontario, Canada
Ionic (gifted), Alta HR (gifted), Charge 2, Flex 2, Charge HR, One, Blaze (retired), Trendweight.com,
Down 150 pounds from my top weight (and still going), sharing my experiences here to try and help others.
