02-29-2024 05:17
02-29-2024 05:17
Hi,
It would be great if you could add other medications and tests related to cycles and ovulation tracking into the Menstrual health tab. That way any additional medical issues related to cycles can easily be tracked and referrenced.
02-29-2024 05:34
02-29-2024 05:34
@EJC32 The best way to give this feedback to Fitbit is through the Product Feedback forum. The Product Feedback forum is monitored by the developers. I also moved your post to the Menstrual Health Tracking forum, a better fit for this topic.
Laurie | Maryland
Best Answer03-01-2024 23:16
03-01-2024 23:16
To enhance the Menstrual Health tab with additional medications and tests related to cycle and ovulation tracking, follow these steps:
Access Settings: Open the app and navigate to the Settings or Preferences section.
Edit Menstrual Health Tab: Look for an option to customize or edit the Menstrual Health tab.
Add Medications: Find a feature that allows you to add medications or supplements. Click on this option to add new medications related to cycle tracking, such as fertility medications or hormone treatments.
Include Tests: Similarly, locate a section where you can add tests or procedures. Here, you can add various tests relevant to ovulation tracking, such as ovulation predictor kits (OPKs), basal body temperature (BBT) tracking, or fertility hormone tests.
Save Changes: After adding the medications and tests, make sure to save your changes to update the Menstrual Health tab.
Review and Refer: Once the Menstrual Health tab is updated, you can easily track additional medical issues related to cycles and refer to them as needed for your healthcare management or discussions with your healthcare provider.
By following these steps, you can expand the functionality of the Menstrual Health tab to include a wider range of medications and tests relevant to cycle and ovulation tracking, providing a comprehensive overview of your menstrual health. indian door design
Best Answer03-02-2024 08:47
03-02-2024 08:47
I looked through the phone app, no such options exist that I can find, only turning it on or off. Is this something that can only be done through the website?
