07-11-2022 08:50
07-11-2022 08:50
Looking for a 30 minute (approximately) meditation which talked about the earth starting with rainforest in New Zealand—it was a woman’s voice. I didn’t get o finish it and can’t find it again. Do meditations change daily on the discover tab? I believe that may have been where I found it. It was called “bright or brave or blue”? Planet?
any suggestions how I can find it? It was a good one!
Best Answer07-11-2022 14:27
07-11-2022 14:27
@Nadinegwen the featured meditations change every day. If you see one that you like, you may want to make it a favorite so you can find it easily again.
The one that you're looking for is called "Green Planet". To find it, tap on the Discover tab and scroll down to Mindfulness. Select that and then select Stories for Sleep. "Green Planet" is listed there.
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
07-11-2022 14:27
Best Answer07-11-2022 14:52
07-11-2022 14:52
09-15-2022 09:17 - edited 09-20-2022 01:54
Meditation is cool, it helps the body relax and recharge. I myself have been practicing meditation for 4 years. It all started when I accidentally went to a meditation app development site and created an app for myself. Therefore, you don't need to search sometimes, but you need to create what you want yourself. So I want to advise everyone, if you can't find what you want, you can just create it.
